I note that one of the Cortex M0+ instruction set has an unusual property:
Unlike LSLS/LSRS/ASRS instructions that support either a 5-bit field (0-31) i.e.
LSRS Rd, #4
or
ASRS Rd, Rs
The RORS instruction only supports:
RORS Rd,Rs
What is more, the definition states:
Rd := Rd ROR Rs[7:0] * C flag unaffected if Rs[7:0] is 0.
So that means that the bottom byte (8 bits) of Rs defines the rotate value. Now I can only presume that there was a very good reason for this but I'm afraid I'm lost. It MAY be of use setting up a handful of 32-bit values into registers that is smaller than using a literal pool.
e.g
0000 0000 0010 0000b x 0000 0000 0010 0000b = 0000 0100 0000 0000
Not a huge boon for quickasm coders but if you happen to have inner-loops that would benefit, maybe it's the saving you need.
I need literally less than 50 instructions of code-fragment beneath which the entire project hangs so I was hoping someone else similarly struggling would find a use for it.
Cheers C
PS is the 64-bytes of cache on the Uno M0 memory mapped?
