Cosa MQTT client library
The second increment of the Cosa MQTT client class is now available. This update will handling incoming publish messages with higher quality of service and correctly respond with acknowledgement messages (PUBACK/PUBREC/PUBCOMP). A new MQTT::Client member function publish_P will allow topic values from program memory buffers.
The typical publish usage pattern is as below:
  // Start ethernet controller and request network address for hostname
  ethernet.begin_P(HOSTNAME));
  // Start MQTT client with socket and connect to server
  client.begin(ethernet.socket(Socket::TCP));
  client.connect(SERVER, CLIENT);
  // Publish data
  client.publish(TOPIC, VALUE, sizeof(VALUE));
  client.disconnect();
The subscribe and service of incoming publish request usage pattern is:
class MQTTClient : public MQTT::Client {
public:
  virtual void on_publish(char* topic, void* buf, size_t count);
void
MQTTClient::on_publish(char* topic, void* buf, size_t count)
  // Handle incoming publish for topic/value
MQTTClient client;
  ethernet.begin_P(HOSTNAME);
  client.begin(ethernet.socket(Socket::TCP)));
  // Subscribe to a topic
  client.subscribe(TOPIC);
  // Service incoming publish messages
  client.service());
Two new MQTT client example sketches are available.
  1. CosaMQTTtemperature
    Reads 1-wire temperature sensor (DS18B20) and publishes to MQTT server.
    Example: https://github.com/mikaelpatel/Cosa/blob/master/examples/MQTT/CosaMQTTtemperature/CosaMQTTtemperature.ino
  2. CosaMQTThumidity
    Reads DHT11 humidity and temperature and publishes on two topics.
    Example: https://github.com/mikaelpatel/Cosa/blob/master/examples/MQTT/CosaMQTThumidity/CosaMQTThumidity.ino
Cheers!
Oh Great thinks |. I must look at the examples.
OH Dear, Dead links!!!
Old stuff. Try https://github.com/mikaelpatel/Cosa/tree/master/examples/IoT/MQTT
Cheers!
