Cosm Template with 4 datastreams
While I was updating my codes from Pachube to Cosm, I find the current documentation for Cosm API was really confusing, not updated or missing info…
They spend so much money on Google Ads but did not get people to clean up the documentations, especially on Arduino portion…
Here is a template I use for my Cosm feeds…
Here is my cosm feeds for those that are interested :-
https://cosm.com/feeds/78111
#include <SPI.h>
#include <Ethernet.h>
#include <HttpClient.h>
#include <Cosm.h>
// Location of the libraries need for Cosm to work
// Cosm Arduino lib : https://github.com/mnin/CosmArduino
// HttpClient lib : https://github.com/amcewen/HttpClient
// MAC address for your Ethernet shield
// Change this if you have more than one Eth Shield on your network
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// Change this to your Cosm key to let you upload data
// The API Key are located at https://cosm.com/users/<cosm_username>/keys
char cosmKey[] = "xxxxxxxXXXXXxxxxxxxx";
// Define the strings for our datastream IDs
// Create the 4 feeds
char sensorId[] = "Range1";
char sensorId2[] = "Range2";
char sensorId3[] = "Temp1";
char sensorId4[] = "Temp2";
// DATASTREAM_INT = integer
// DATASTREAM_FLOAT = float
CosmDatastream datastreams[] = {
  CosmDatastream(sensorId, strlen(sensorId), DATASTREAM_INT),  // define this ID in cosm
  CosmDatastream(sensorId2, strlen(sensorId), DATASTREAM_INT), // define this ID in cosm
  CosmDatastream(sensorId3, strlen(sensorId), DATASTREAM_INT), // define this ID in cosm
  CosmDatastream(sensorId4, strlen(sensorId), DATASTREAM_INT), // define this ID in cosm
// Finally, wrap the datastreams into a FeedID, change this
CosmFeed feed(78111, datastreams, 4 );  // Using 4 feeds with FeedID of 78111, get from cosm
// I use static IP address for easy troubleshooting
IPAddress ip(192,168,0,50);             // Static IP address
EthernetClient client;
CosmClient cosmclient(client);
void setup(){
   Serial.println("Starting single datastream upload to Cosm...");
// Setting up Ethernet static IP address
   Serial.println("Starting Ethernet Client...");
   Ethernet.begin(mac, ip);
   Serial.println("Ethernet client & IP address OK");
  int A,B,C,D = 0;             // Change to your sensor variable names
  int cosmReturn = 0;
  // Put your sensor input code here
  // Put sensor values into the 4 datastreams,
  // setInt() for integer
  // setFloat() for floating point
  datastreams[0].setInt(A);    // Set sensor values into datastreams 1
  datastreams[1].setInt(B);    // Set sensor values into datastreams 2
  datastreams[2].setInt(C);    // Set sensor values into datastreams 3
  datastreams[3].setInt(D);    // Set sensor values into datastreams 4
  // getInt for integer, getFloat for floating point
  Serial.print("A:");
  Serial.println(datastreams[0].getInt());  // Print datastream to serial monitor
  Serial.print("B:");
  Serial.println(datastreams[1].getInt());  // Print datastream to serial monitor
  Serial.print("C:");
  Serial.println(datastreams[2].getInt());  // Print datastream to serial monitor
  Serial.print("D:");
  Serial.println(datastreams[3].getInt());  // Print datastream to serial monitor
  // This line send the feed to cosm, while testing/debugging your codes, comment it out
   cosmReturn = cosmclient.put(feed,cosmKey);   // Send feed to cosm
   Serial.print("COSM client returned : "); // Get retern code, similar to HTTP code
   Serial.println(cosmReturn);
  delay(2000); // Put a delay before the next updates to Cosm
Thanks Stanley
I have been having a nightmare of a time with cosm. I finally got a result with a single feed using the new libraries. Your code gave me the breakthrough I needed for multiple data.
https://cosm.pachube.com/feeds/83153
I'm glad you find it useful..
With Arduino, I want everyone to be able to use it easily and easy to read the codes too...
Hi Stanley I agree with Nick, I have been pulling my hair out, thanks a million. However, I am for some reason only getting 0.00 as my float value in Cosm and via serial monitor, I am doing something wrong but it seems so straightforward I can't think what. I am simply doing an analogRead straight to the variable (A) for testing. Any help appreciated, I am not very good at this yet.....
Cheers John
  //float A,B,C,D = 0;             // Change to your sensor variable names
  int cosmReturn = 0;
  float A = analogRead(A0);
  float B = analogRead(A1);
  float C = analogRead(A2);
  float D = analogRead(A3);
  datastreams[0].setFloat(A);    // Set sensor values into datastreams 1
  datastreams[1].setFloat(B);    // Set sensor values into datastreams 2
  datastreams[2].setFloat(C);    // Set sensor values into datastreams 3
  datastreams[3].setFloat(D);    // Set sensor values into datastreams 4
I totally cheat in my uploads of data to cosm. I use comma separated values in a string, then define them on the site. I was too darn lazy to work out the json for it.
It turned around and bit me though when I started to bring the data back for charting. I had to break down and learn how to parse the darn json values returned. Still use the csv format for sending data up though.
Hi, I have an Arduino test program that successfully sends both INT and FLOAT data to Cosm.com
It's on the http://ArduinoInfo.Info WIKI here:
http://arduino-info.wikispaces.com/Cosm-Arduino
UPDATE: I have developed real-data examples with DHT11 (Temp-Humidity) and DS18B20 Temp (not done yet) and they are shown there, along with better how-to setup etc.
Thanks for the help, very nice easy to follow work.
Cheers
John
Thanks for the post,
Very helpful and working well :)
https://cosm.com/feeds/106332
i have a problem with using an HD44780 20X4 lcd with the arduino Uno and ethernet shield. I load code unto it but it doesn't display anything. i need help. i used the code from the website. http://www.betasix.net/connecting-a-amc2004a-hd44780-compatible-lcd-to-arduino/
#include <Wire.h> //I2C library
void i2c_eeprom_write_byte( int deviceaddress, unsigned int eeaddress, byte data ) {
int rdata = data;
Wire.beginTransmission(deviceaddress);
Wire.send((int)(eeaddress >> 8)); // MSB
Wire.send((int)(eeaddress & 0xFF)); // LSB
Wire.send(rdata);
Wire.endTransmission();
// WARNING: address is a page address, 6-bit end will wrap around
// also, data can be maximum of about 30 bytes, because the Wire library has a buffer of 32 bytes
void i2c_eeprom_write_page( int deviceaddress, unsigned int eeaddresspage, byte* data, byte length ) {
Wire.send((int)(eeaddresspage >> 8)); // MSB
Wire.send((int)(eeaddresspage & 0xFF)); // LSB
byte c;
for ( c = 0; c < length; c++)
Wire.send(data
  byte i2c_eeprom_read_byte( int deviceaddress, unsigned int eeaddress ) {
    byte rdata = 0xFF;
    Wire.requestFrom(deviceaddress,1);
    if (Wire.available()) rdata = Wire.receive();
    return rdata;
  // maybe let's not read more than 30 or 32 bytes at a time!
  void i2c_eeprom_read_buffer( int deviceaddress, unsigned int eeaddress, byte *buffer, int length ) {
    Wire.requestFrom(deviceaddress,length);
    int c = 0;
    for ( c = 0; c < length; c++ )
      if (Wire.available()) buffer[c] = Wire.receive();
    char somedata[] = "this is data from the eeprom"; // data to write
    Wire.begin(); // initialise the connection
    i2c_eeprom_write_page(0x50, 0, (byte *)somedata, sizeof(somedata)); // write to EEPROM
    delay(10); //add a small delay
    Serial.println("Memory written");
    int addr=0; //first address
    byte b = i2c_eeprom_read_byte(0x50, 0); // access the first address from the memory
    while (b!=0)
      Serial.print((char)b); //print content to serial port
      addr++; //increase address
      b = i2c_eeprom_read_byte(0x50, addr); //access an address from the memory
    Serial.println(" ");
    delay(2000);
I got this code from the arduino website but it is giving me this error "wire.send has been renamed write.write ". How do i solve the error.
http://playground.arduino.cc/Code/I2CEEPROM#.UztWn_ldWSo
............ Now tell us this has something to do with datastreams to cosm
