I have successfully setup a feed on Cosm using the CosmClient sketch. I setup a trigger to tweet on twitter if the value is >800. I can click the Send a Test Trigger to send the tweet manually, however when I change the value to something above 800 and wait 5 minutes (as I specify) no tweet is sent. When I refresh https://cosm.com/feeds/88927 the trigger time goes back to 6 hours. Has anyone else experienced this? Will Cosm set a trigger for every 5 minutes?
nevermind. Appearantly if the score is already above 800 when starting, then another tweet will not be sent. The 5 minutes is simply for graphing purposes.
