Could analogRead detect a 60Hz sine wave?
I'm trying to create a 'zero cross detector' within my Arduino code. The analog input will be a 60 hz, 5Vp-p sine wave. I want to create a counter within the code to monitor every time the sine wave crosses zero (every 8.33mS), because my digitalWrite pulse is based on this timing. I had an external zero cross detector used as a digital input to my Arduino however it doesn't seem to work too efficiently. Is there an easier way to do this??? Thank you! :slight_smile:
You and we need to figure out why the digital method isn't working efficiently. Trying to use analog measurements to detect zero crossings is the most inefficient method I can think of.
Post what the external digital zero crossing circuit looks like, how it's wired to the arduino, and finally the code being used to count the zero crossings.
Lefty
I'm hoping your signal starts at 0V and goes to 5V. Assuming it does, there is an analog comparator on board, which you could set to a low threshold and detect when that is crossed. That will be much faster than doing analog reads.
Lefty,
yeah I guess I should have given more info regarding that topic. I have a few lab results I snapped pictures of.
One of my pictures is the zero cross detect. It's hard to visually see, but only every other pulse is a true zero detect because they RISE at the cross, while the middle ones FALL at the cross:
http://bayimg.com/haKfKAaeg
The I achieved this zero cross circuit over the internet with the following schematic:
http://bayimg.com/HaKfmAaEg
I didn't care too much about this because it's inaccuracy is only in the microseconds, however after my output pulse results I started to question my digitalRead and Zero cross detection circuit:
http://bayimg.com/hAKFlAaEG
I have the zero cross detection pulse going into my digitalRead pin.
My pulse delays are based on how many times zero cross has occurred.
The zero cross' purpose is for synchronization.
Below is my desired output pulse (only showing positive pulse, coding has both):
http://bayimg.com/IAkFAaAeG
Here is my code shown below:
///Arduino SCR firing revised
int zC = 7; /// zero detect input 7
int x = 0; ///phase angle firing reference
int y = 0; /// zero cross count
float z = 0; /// time delay in decimals
int SCR1 = 1;
int SCR2 = 2;
int SCR3 = 3;
int SCR4 = 4;
  pinMode (zC, INPUT);
  pinMode (SCR1, OUTPUT);
  pinMode (SCR2, OUTPUT);
  pinMode (SCR3, OUTPUT);
  pinMode (SCR4, OUTPUT);
  if (digitalRead(zC) == HIGH)
    x = x++;
    y = y++;
  switch (y) {
    case 1:
    z = 4.16;  //90 degrees
    case 30: //250mS
    z = 3.9;  //85 degrees
    case 60:  //500mS
    z = 3.7; //80 degrees
    case 90: //750mS
    z = 3.47; //75 degrees
    case 120: //1000mS
    z = 3.23; //70 degrees
    case 150: //1250mS
    z = 3.0; //65 degrees
    case 180: //1500mS
    z = 2.77; //60 degrees
    case 210: //1750mS
    z = 2.54; //55 degrees
    case 240: //2000mS
    z = 2.31; //50 degrees
    case 270: //2250mS
    z = 2.08; //45 degrees
    case 300: //2500mS
    z = 1.85; //40 degrees
    case 330: //2750mS
    z = 1.61; //35 degrees
    case 360: //3000mS
    z = 1.38; //30 degrees
    case 390: //3250mS
    z = 1.15; //25 degrees
    case 420: //3500mS
    z = 0.92; //20 degrees
    case 450: //3750mS
    z = 0.694; //15 degrees
    case 480: //4000mS
    z = 0.462; //10 degrees
    case 510: //4250mS
    z = 0.231; ///5 degrees
    case 540: //4500mS
    z = 0.0; ///0 degrees
  if (x == 1)
    delay(z);
    digitalWrite(1, HIGH);
    digitalWrite(1, LOW);
    digitalWrite(4, HIGH);
    digitalWrite(4, LOW);
  if (x == 2)
    delay(z);
    digitalWrite(2, HIGH);
    digitalWrite(2, LOW);
    digitalWrite(3, HIGH);
    digitalWrite(3, LOW);
    x = 0;
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
I apologize, that looks much cleaner.
    x = x++;
    y = y++;
I'm not sure this is valid. Try either:
    x = x + 1;
    y = y + 1;
or:
    x++;
    y++;
I'm not sure what your question is (a couple of posts up).
I'm right, I think.
i = i++;
... is undefined.
http://c-faq.com/expr/seqpoints.html
Also:
