Could not connect to YunServer 146 Connection refused
I read many post, bat I have not found a solution to the problem. I use example Bridge sketch from Arduino IDE 1.5.7. Any help? Or just this functionality will never work in Arduino and might not be able to work?
At basic configuration page, turn off the REST password requirement.
sjanek:
Can you describe what your problem is? That error message is expected if your sketch is NOT Bridge library powered.
What did you do to get the error? Please describe each single step in detail so that we can help you.
sonnyyu:
if this is the case there has to be a way to pass password to authenticate
