I am getting this mistake: could not convert 'ServoRechts()' from 'void' to 'bool'
Can someone Help me?
This is my programm:
#include <HCSR04.h>
#include<Servo.h> //Bibliothek Sensor
Servo S1;
int a;
float distanceH;
const byte triggerPin = 13; //Trigger Pin - Sensor Front
const byte echoPin = 12; //Echo Pin - Sensor Front
UltraSonicDistanceSensor distanceSensor(triggerPin, echoPin); // Sensor vorne
const byte triggerPin2 = 44; //Trigger Pin - Sensor hinten
const byte echoPin2 = 42; //Echo Pin - Sensor hinten
UltraSonicDistanceSensor distanceSensor2(triggerPin2, echoPin2); // Sensor hinten
/*pinMode (11, INPUT_PULLOUT); // Taster Servo rechtskurve
pinMode (10, INPUT_PULLOUT); // Taster Servo linkskurve
pinMode (6, INPUT_PULLOUT); // Taster Servo gradeaus*/
pinMode(3, OUTPUT); //motor
pinMode(4, OUTPUT); //motor
pinMode(31, OUTPUT);//Lautsprecher
pinMode(30, OUTPUT); //LED links
pinMode(32, OUTPUT); //LED rechts
pinMode(9, OUTPUT); //Servo lenkung
S1.attach(9); //Servo
Serial.begin (9600);}
void ServoRechts(){
S1.write(15);}
void ServoLinks(){
S1.write(155);}
void Servogerade(){
S1.write(88);}
void Abstandsttone(){
/*void Bremslicht(){
if()}*/
void SensorVorne(){ //Ultraschallsensor 1 vorne
float distance = distanceSensor.measureDistanceCm();
Serial.println(distance);
delay(500);}
void SensorHinten(){//Ultraschallsensor 2 hinten
float distanceH = distanceSensor2.measureDistanceCm();
Serial.println(distanceH);
delay(500);}
void vorfahren(){
digitalWrite (3,HIGH); //motor
digitalWrite (4,LOW);
delay (100);
digitalWrite (3,LOW);
digitalWrite (4,HIGH);
delay(5000);
delay(5000);} //motor
void rueckfahren(){
digitalWrite (3,LOW); //motor
delay(100);
delay(5000);
void blinkenR(){
if(ServoRechts()){
digitalWrite(32,HIGH);
delay(100);
digitalWrite(32,LOW);
delay(100);
delay(100);
digitalWrite(32,LOW);}}
void blinkenL(){
if(ServoLinks()){
digitalWrite(30,HIGH);
delay(100);
digitalWrite(30,LOW);
delay(100);
delay(100);
digitalWrite(30,LOW);}}
void StopV(){
if(distance<6){
digitalWrite (3,LOW); //motor wird ausgemacht
digitalWrite (4,LOW);}}
void StopH(){
if(distance<6){
