Could not scan for EEPROM, 24CW64X ,4-balls
Hi Everyone!
I recently bought a few EEPROM of type 24CW64X ,4-balls. The data sheet is as shown here:
http://ww1.microchip.com/downloads/en/DeviceDoc/24CW16X_32X_64X%20I2C%20Serial%20EE%20with%20Software%20Write%20Protection_DS20005772A.pdf
I have connected the 4 balls on this memory device, according to their supply voltage (Vcc), ground voltage (Vss), Serial data Pin( SDA) and serial clock input (SCL), to the Arduino Uno, and connected pull-up resistors of 2kOhms (as mentioned in the data sheet) to both the SDA and SCL.
However, when i tried scanning for this device using the code from this website:
https://playground.arduino.cc/Main/I2cScanner
, I usually get errors for some of the EEPROMs such as: "No device found."
or errors such as: "Unknown error at address 0x25 Unknown error at address 0x30 Unknown error at address 0x55"
I am thinking that this memory device may require me to first remove the write protect or to perhaps change the slave address first through the Hardware Address Register?
I am stuck now at this stage, and being a beginner in electronics and coding, it will be great if any one can provide help. Thank you very much!
-Gabriel
