#include <Servo.h>
//Servos
Servo servoPan;
Servo servoTilt;
int anlge = 0;
//Drive pins
const int drivePin1 = 3;
const int drivePin2 = 4;
const int enablePin1 = 7;
//Steering pins
const int steerPin1 = 5;
const int steerPin2 = 6;
const int enablePin2 = 8;
//Serial information varriables
char inSerial;
//Pan Variables
Servo panServo; //Panning servo
const int panPin = 10;
bool bPan; // If true enables the ability for the servo to pan
bool bPanDirPos; //If true servo should pan only in the positive direction
float panSpeed = .01; //Degrees in which servo pans per tic
float panVal = 60; //Panning servo starting position
//Tilt Variables
Servo tiltServo; //Tilting servo
const int tiltPin = 9;
bool bTilt; // If true enables the ability for the servo to tilt
bool bTiltDirPos; //If true servo should tilt only in the positive direction
float tiltSpeed = .01; //Degrees in which servo tilts per tic
float tiltVal = 90; //Tilting servo starting position
Serial.begin(115200); //serial connection number
pinMode(drivePin1, OUTPUT);
pinMode(drivePin2, OUTPUT);
pinMode(enablePin1, OUTPUT);
pinMode(steerPin1, OUTPUT);
pinMode(steerPin2, OUTPUT);
pinMode(enablePin2, OUTPUT);
digitalWrite(enablePin2, HIGH);
Serial.println("Setup Complete");
//Initalize Servos to starting positions
//Pan Servos
panServo.attach(panPin);
panServo.write(panVal);
bPan = false;
bPanDirPos = true;
//Initalize Tilt Servos
tiltServo.attach(tiltPin);
tiltServo.write(tiltVal);
bTilt = false;
bTiltDirPos = true;
void SteerLeft()
digitalWrite(steerPin1, HIGH);
digitalWrite(steerPin2, LOW);
void SteerRight()
digitalWrite(steerPin1, LOW);
digitalWrite(steerPin2, HIGH);
void SteerStop()
digitalWrite(steerPin1,LOW);
digitalWrite(steerPin2,LOW);
void DriveForward()
digitalWrite(enablePin1, HIGH);
digitalWrite(drivePin1, LOW);
digitalWrite(drivePin2, HIGH);
void DriveBackward()
digitalWrite(drivePin1, HIGH);
digitalWrite(drivePin2, LOW);
void DriveStop()
void PanUp()
bPan = true;
bPanDirPos = true;
void PanDown()
bPan = true;
bPanDirPos = false;
void PanStop()
bPan = false;
void TiltUp()
bTilt = true;
bTiltDirPos = true;
void TiltDown()
bTilt = true;
bTiltDirPos = false;
void TiltStop()
bTilt = false;
//read the serial data into the buffer
if(Serial.available() > 0)
inSerial = Serial.read();
if(inSerial == 'w')
DriveForward();
else if(inSerial == 'b')
DriveBackward();
else if(inSerial == 's')
digitalWrite(enablePin1, LOW);
else if(inSerial == 'l')
SteerLeft();
else if(inSerial == 'r')
SteerRight();
else if(inSerial == 'q')
SteerStop();
else if(inSerial == 'p')
PanUp();
else if(inSerial == 'c')
PanDown();
else if(inSerial == 't')
TiltUp();
else if(inSerial == 'x')
TiltDown();
else if(inSerial == 'g')
TiltStop();
//Controll panning
if(bPan)
if(bPanDirPos)
if(panVal<180)
panVal+=panSpeed;
if(panVal>0)
panVal-=panSpeed;
//Controll Tilting
if(bTiltDirPos)
if(bTiltDirPos)
if(tiltVal <180)
tiltVal +=tiltSpeed;
This doesn't look right:
//Controll Tilting
if(bTiltDirPos)
if(bTiltDirPos)
Based on what you have in the previous if statement for bPan, I suspect you meant:
//Controll Tilting
if(bTilt)
if(bTiltDirPos)
Pete
What's the difference between ServoPan and PanServo? You never write low to eablepin1 in drivestop, and you never call drivestop (call it when you receive an 's').
