hi all,
the pice of code is meant to convert analog signal to digital then send it to pin D37 in due board.
#include <arduino.h>
/* DEFINES */
#define IN_PIN A0
#define LED_PIN 37 //LED is on PIn?
#define BYTE_SIZE 12
#define TX_DELAY 16
//#define PIN_T 36
//#define DEBUG_ON
/* Global Variables */
int Audio_inp = 0; //Input from Audio
/* Function Definitions */
void Output_Data(int);
REG_ADC_MR = (REG_ADC_MR & 0xFFF0FFFF) | 0x00020000;// to fast the analog read function
#ifdef DEBUG_ON
#endif
pinMode (IN_PIN,INPUT);
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, LOW); //OFF
analogReadResolution(BYTE_SIZE);
/* Function : Output byte to the Signal signal
void Output_Data(int val)
short aux = BYTE_SIZE;
#ifdef DEBUG_ON
#endif
while(aux > 0)
if( (val & (1 << (aux-1)))) // We check each bit from LSB to MSB
digitalWrite(LED_PIN, HIGH); //ON
#ifdef DEBUG_ON
Serial.println ("high");
#endif
#ifdef DEBUG_ON
Serial.println ("low");
#endif
aux--;
delayMicroseconds(TX_DELAY);
#ifdef DEBUG_ON
/* unsigned long start, stop_time;
start = micros();
Audio_inp = analogRead(A0);
stop_time = micros();
Serial.println(stop_time - start);*/
#endif
Audio_inp = analogRead(IN_PIN);
if(Audio_inp < 0)
Audio_inp = 0;
Output_Data(Audio_inp);
#ifdef DEBUG_ON
#endif
could someone help me out, becose i am getting oupt in pin d37 even analog input pin isn't connected. beside i can't see the any output in Serial window neither.
any help would be greatly appreciated,
regards,
M,
