Could the code be used with this SDcard connection
Hello everyone,
according the link of SDcard read and write tutorial
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1206874649
if i just wanted to write things into the SDcard, i could delete the
section of " int readDisk; " ?
if it does, what things can be also deleted ?
The content is changed, sorry for the previous reader
i need much more help with the SDcard write
i don't know how to write this
i will keep trying, please help
Thanks a lot :slight_smile:
for this code below, could it automatically create the file that i would like to save the data to ?
#include <sd-reader_config.h>
#include <sd_raw.h>
#include <sd_raw_config.h>
int print_disk_info();
int sample();
int readDisk();
byte incomingByte;
void printWelcome();
long int address;
byte tempBytes[2];
  printWelcome();
  if(!sd_raw_init())
     Serial.println("MMC/SD initialization failed");
  print_disk_info();
    int i;
    if(Serial.available()>0)
         incomingByte=Serial.read();
       switch(incomingByte)
           case 114:
                     readDisk();
           case 115:
                     sample();
           default:
int sample()
    int i,j;
    int temp;
    byte low;
    byte high;
    byte inByte;
    Serial.println("Sampling..");
    for(i=0;i<500;i=i+2)
            inByte=Serial.read();
            if(inByte==113) return 0;
        temp=analogRead(0);
        Serial.print(temp,DEC);
        Serial.print(" ");
        //Convert int to 2 bytes
        low=temp&0xFF;
        high=temp>>8;
       // Serial.print(temp,DEC);
        //Serial.print(low,DEC);
        //Serial.print(high,DEC);
        tempBytes[0]=low;
        tempBytes[1]=high;
        if(!sd_raw_write(i,tempBytes,2))
          Serial.print("Write error");
        //sd_raw_sync();
        delay(5000);
    return 1;
int readDisk()
    byte low;
    byte high;
    byte info[2];
    int i;
    int  result;
    for(i=0;i<50;i=i+2)
        sd_raw_read(i,info,2);
        //Serial.print(info[0],DEC);
        //Serial.print(" ");
        //Serial.print(info[1],DEC);
        low=info[0];
        high=info[1];
        result=high<<8;
        //result<<8;
        Serial.print(" ");
        Serial.print(result+low,DEC);
        Serial.print(" ");
void printWelcome()
    Serial.println("------------------------");
    Serial.println("Data sampling system");
    Serial.println("send r to read disk");
    Serial.println("send s to start sampling");
    Serial.println("send q to stop sampling");
    Serial.println("Ready.....");
    Serial.println("-------------------------");
    struct sd_raw_info disk_info;
    if(!sd_raw_get_info(&disk_info))
        return 0;
    Serial.print("rev:    ");
    Serial.print(disk_info.revision,HEX);
    Serial.print("serial: 0x");
    Serial.print(disk_info.serial,HEX);
    Serial.print("date:   ");
    Serial.print(disk_info.manufacturing_month,DEC);
    Serial.print(disk_info.manufacturing_year,DEC);
    Serial.print("size:   ");
    Serial.print(disk_info.capacity,DEC);
    Serial.print("copy:   ");
    Serial.print(disk_info.flag_copy,DEC);
    Serial.print("wr.pr.: ");
    Serial.print(disk_info.flag_write_protect_temp,DEC);
    Serial.print('/');
    Serial.print(disk_info.flag_write_protect,DEC);
    Serial.print("format: ");
    Serial.print(disk_info.format,DEC);
    Serial.print("free:   ");
    return 1;
How to tell the arduino to create a txt file in the SDcard?
I think the intention is that you create the txt file on a PC before you connect it to the Arduino.
You have to admit, though, this is a pretty severe limitation.
I haven't looked in any detail, but I have often wondered a) why this is the case (that you have to pre-create the files), and b) why hasn't somebody fixed it?
:slight_smile:
Its probably a messy and resources costly bit to implement on an arduino....
oh
then the file is need to be created in the first place.
there is a data, A for instance, i would like to save "A" to the SDcard
i saw that there is a code
int readDisk();
i can delete this section, right? if i just write things into the SDcard.
oh, the limitation you meant is that could not create the txt file automatically?
if i pre-created the file, let's say the file name is B for instance,
how to tell the arduino to save the data into B ?
Are there any others saving method that using the SDcard ?
please suggest it if you have any recommendations , i very appreciate it
It would help a lot to my project,
and seriously, can help me to graduate
Thanks a lot
IIRC it is only the demo program that requires the file to be created.
I believe you want to add the FAT library. This will you give a FAT file system
and you can create, read and write files.
(* jcl *)
www: http://www.wiblocks.com
twitter: http://twitter.com/wiblocks
blog: http://luciani.org
is it this library ?
http://code.google.com/p/sdfatlib/downloads/list
for the code i posted on third reply, i couldn't find the code of writing data into the SD card , which section in the code that i should look further to change the code that suitable for me ?
Google Code Archive - Long-term storage for Google Code Project Hosting.
I believe so. Also ladyada has a library too (which I believe was derived from
the one you linked to).
(* jcl *)
i have some question with the datalogging without the library
there is a tutorial from here : Arduino Playground - SDCARD
the SPI section must be needed ?
and if i need to write thing into the SDcard
these two code, SPI section and writing of SDcard section are both needed ?
/********************** SPI SECTION BELOW **********************/
// SPI Variables
byte clr;     // dummy variable used to clear some of the SPI registers
byte spi_err; // SPI timeout flag, must be cleared manually
// send an SPI command, includes time out management
// returns spi_err: "0" is "no error"
byte spi_cmd(volatile char data) {
  spi_err = 0; // reset spi error
  SPDR = data; // start the transmission by loading the output byte into the spi data register
  int i = 0;
  while (!(SPSR & (1<<SPIF))) {
    i++;
    if (i >= 0xFF) {
      spi_err = 1;
      return(0x00);
  // returned value
  return(SPDR);
// initialize SPI port
void spi_initialize(void) {
  SPCR = (1<<SPE) | (1<<MSTR); // spi enabled, master mode
  clr = SPSR; // dummy read registers to clear previous results
  clr = SPDR;
// write block on SD card
// addr is the address in bytes (multiples of block size)
void sdc_writeBlock(long blockIndex) {
  byte retries=0;
  while(sdc_cmd(WRITE_BLOCK, blockIndex * blockSize) != 0x00) {
    delay(1);
    retries++;
    if (retries >= 0xFF) return; // timed out!
  spi_cmd(0xFF); // dummy byte (at least one)
  // send data packet (includes data token, data block and CRC)
  // data token
  spi_cmd(0xFE);
  // copy block data
  for (int i=0; i<blockSize; i++) {
    spi_cmd(vBlock[i]);
  // write CRC (lost results in blue sky)
  spi_cmd(0xFF); // LSB
  spi_cmd(0xFF); // MSB
  // wait until write is finished
  while (spi_cmd(0xFF) != 0xFF) delay(1); // kind of NOP
hello to everyone,
forget the previous code that i posted,
i have found a code that from arduino playground
there is a example from the sdfat library,
but i don't know how to connect the SDcard to the ATmega168
here is the library that i download, have a look please
http://code.google.com/p/fat16lib/downloads/detail?name=fat16lib20100131.zip&can=2&q=
i really really need this datalogging, please help me out, i am going crazy with the code
Here is the SDfat write code,
#include <Fat16.h>
#include <Fat16util.h> // use functions to print strings from flash memory
SdCard card;
Fat16 file;
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char *str)
  PgmPrint("error: ");
  SerialPrintln_P(str);
  if (card.errorCode) {
    PgmPrint("SD error: ");
    Serial.println(card.errorCode, HEX);
  while(1);
 * Write an unsigned number to file
void writeNumber(uint32_t n)
  uint8_t buf[10];
  uint8_t i = 0;
  do {
    i++;
    buf[sizeof(buf) - i] = n%10 + '0';
    n /= 10;
  } while (n);
  file.write(&buf[sizeof(buf) - i], i); // write the part of buf with the number
void setup(void)
  PgmPrintln("Type any character to start");
  while (!Serial.available());
  // initialize the SD card
  if (!card.init()) error("card.init");
  // initialize a FAT16 volume
  if (!Fat16::init(card)) error("Fat16::init");
  // create a new file
  char name[] = "WRITE00.TXT";
  for (uint8_t i = 0; i < 100; i++) {
    name[5] = i/10 + '0';
    name[6] = i%10 + '0';
    // O_CREAT - create the file if it does not exist
    // O_EXCL - fail if the file exists
    // O_WRITE - open for write
    if (file.open(name, O_CREAT | O_EXCL | O_WRITE)) break;
  if (!file.isOpen()) error ("file.open");
  PgmPrint("Writing to: ");
  Serial.println(name);
  // write 100 line to file
    file.write("line "); // write string from RAM
    writeNumber(i);
    file.write_P(PSTR(" millis = ")); // write string from flash
    writeNumber(millis());
    file.write("\r\n"); // file.println() would work also
  // close file and force write of all data to the SD card
  file.close();
  PgmPrintln("Done");
void loop(void) {}
Why are you worried about the code if you don't have the hardware connected correctly?
i am pushing myself too hard, i don't know what to say :frowning:
i am graduating, so there is a lot of stress around me
thanks to you that i have the frequency counter code succeeded, thanks a lot
now i am trying to save the data, i am worrying that if SDcard circuit could help me, here is a question about the SDcard, i saw a schematic inside the fat16library, it is showing the SDcard connection, here it is.
if i need to use the fat16 example from the library, the connection should be like the picture on the above, or the tutorial can also work ?
what is 4050N ?
There is a very long uSD thread on this forum. IIRC there are links to uSD and SD
card schematics in one of the early posts.
(* jcl *)
what is 4050N
It's a buffer. In this circuit it is translating 5V TTL levels to the 3.3V TTL levels
required by the SD Card.
(* jcl *)
