After 5 years of no programmin at all I am a bit rusty so I need some advise on the code here. firdt the def's
int posXaxis = 90; // variable to store the servo position
int posYaxis = 90; // variable to store the servo position
String axisValueString ;
and from the main-loop this routine is called
* This routine wil decode a received string
* in this format "123.4,567.8\n" into two
* numbers to control a servo
void readData(char ch) {
if (ch == ',') {
// create servo-X value to move to
posXaxis = 0;
posXaxis = axisValueString.toInt();
axisValueString = "";
// skip decimal point
if (ch != '.') {
axisValueString += ch;
if (ch == '\n') {
// create servo-Y value to move to
posYaxis = 0;
posYaxis = axisValueString.toInt();
Define "smart code"! Is it the shortest code, the fastest code or the most understandable code some years later?
I've seen "smart code" that almost nobody understand, almost nobody could maintain, update...
I would not use a 'String' just for the conversion. I would add each digit to the number individually.
static unsigned int value = 0;
if (ch >= '0' && ch <= '9')
value = (value * 10) + (ch - '0');
if (ch == ',')
posXaxis = value;
value = 0;
if (ch == '\n')
posYaxis = value;
value = 0;
posXaxis = Serial.parseInt(SKIP_ALL, '.'); // read an int, skipping any preceding \n, ignoring decimal point
posYaxis = Serial.parseInt(SKIP_ALL, '.'); // read an int, skipping the comma, ignoring decimal point
johnwasser:
if (ch == ',')
posXaxis = value;
value = 0;
if (ch == '\n')
posYaxis = value;
value = 0;
Tested the code in my sketch true the terminal, first 0 then 90 and 180 degrees.
X=>0/0
Y=>0/0
==Move Servo==
New position deg.=>0/0
New position msec=>1000/1000
X=>900/900
Y=>900/900
==Move Servo==
New position deg.=>900/900
New position msec=>1500/1000
X=>1800/1800
Y=>1800/1800
==Move Servo==
New position deg.=>1800/1800
New position msec=>2000/1000
jt looks that the X goes OK but the Y doenst. Here's my main loop:
// send data only when you receive data:
if (Serial.available() > 0) {
readData(Serial.read());
if (valueX == true && valueY == true) {
Serial.println("==Move Servo==");
Serial << "New position deg.=>" << posXaxis << "/" << posYaxis << endl;
Serial << "New position msec=>" << degree2ms(posXaxis / 10) << "/" << degree2ms(newYAxis / 10) << endl;
servoXaxis.writeMicroseconds(degree2ms(posXaxis)); // tell servo to go to position in variable 'pos'
We need to see ALL your code, from the first line to the last.
What model Arduino are you using?
What are you trying to do with your code?
What hardware is connected?
Can you please post your circuit diagram to help us read your code?
if (Serial.available() >= 12) {
