darbye:
I have the wiring down but I cant figure out the coding. I have the concept of how a shift register works but I can't figure out how to write the code and send the bits based on the reading from the pressure sensors.
Well, you put the bits into bytes. Then you shift out the bytes. Which part are you having a problem with?
