I am brand new to Arduino and don't actually have anything yet. I am in the process of ordering parts.
My knowledge is limited to some Java I learned in college so I'll cross that bridge when I come to it.
I have done some research and have found that transistors should be used when they are able to handle a load and relays should be used when they can't.
I was wondering if I could use this transistor (IRLB8721) to power 3014 chipset LED strips and if so, how many LED strips could one transistor handle?
It would be helpful for me to understand how to tell what a certain transistor is capable of so could anyone explain it to me or have a link to somewhere that does this?
Thanks for the link. I actually came across this site which is where I found the IRLB8721.
If I understand correctly, the IRLB8721 can support 16 Amps at 12 Volts.
So if 5M of LED strips uses 72 Watts that is equal to 72 divided by 12 which is 6 Amps.
If my math is correct (I really don't know), I can comfortably use one IRLB8721 transistor for two 5M strips of lights for a total of 144 Watts at 12V 12A.
Does this work? I'm just trying not to burn my house down.
donldmn:
I didn't even think about running them in parallel.
Thanks for the help I think I'll experiment when I get them.
I was thinking of using a spare computer PSU.
"Regular" transistors can't be paralleled but MOSFETs can. It's still better to buy a transistor of the appropriate size as then there's less wires to get tangled.
One technique for large LED arrays is to use a number of power supplies and a number of MOSFETs but don't try to parallel them. Each supply+transistor controls its own strip. The grounds of all power supplies should be connected or you would need extra electronics to control each one.
I'd probably use an IRF3708PBF; the Rds(on) is lower, and they're a good go-to power MOSFET because they can be controlled from 3.3v logic levels too. Will still need a heatsink.
One concern - if you're PWMing it, you may find that the MOSFET gets hotter than you expect - this is because during the time that it's being turned on and off, for a brief moment, it is partially on with a much higher resistance (the gate acts like a capacitor, so switching takes a non-zero time). Depending on the amount of current and how strong the drive is, this may or may not be a problem. If it turns out that it is, you need a MOSFET driver (this is a little IC with a pair of caps on it and it's own internal switches that is capable of dumping very high current into (or drawing it out of) the gate to switch it on and off very quickly.
