Could you help me with sleep mode and watchdog ?
Hello!
I’m creating a sketch which Arduino will run over batteries, so, low power is a must have.
I copied a sketch from internet, however, the max. time the watchdog timer takes to reset my Arduino can be set to 8 seconds.
I need my Arduino to execute the code inside the MyFunction() once every 5 minutes, THEN go sleep.
How can I prolongue the Sleep mode for about 5 minutes?
Thank you so much.
#include <avr/sleep.h>
#include <avr/wdt.h>
const byte LED = 5;
// watchdog interrupt
ISR (WDT_vect)
   wdt_disable();  // disable watchdog
}  // end of WDT_vect
void MyFunction(){
  pinMode (LED, OUTPUT);
  digitalWrite (LED, HIGH);
  delay (50);
  digitalWrite (LED, LOW);
  pinMode (LED, INPUT);
void setup () {
void loop ()
 MyFunction();
  // disable ADC
  ADCSRA = 0;
  // clear various "reset" flags
  MCUSR = 0;
  // allow changes, disable reset
  WDTCSR = bit (WDCE) | bit (WDE);
  // set interrupt mode and an interval
  WDTCSR = bit (WDIE) | bit (WDP3) | bit (WDP0);    // set WDIE, and 8 second delay
  wdt_reset();  // pat the dog
  set_sleep_mode (SLEEP_MODE_PWR_DOWN);
  noInterrupts ();           // timed sequence follows
  sleep_enable();
  // turn off brown-out enable in software
  MCUCR = bit (BODS) | bit (BODSE);
  MCUCR = bit (BODS);
  interrupts ();             // guarantees next instruction executed
  sleep_cpu ();
//  cancel sleep as a precaution
  sleep_disable();
  } // end of loop
HINT :
How many 8 Seconds are there in 5 Minutes?
missdrew:
HINT :
Seems like you're suggesting me to create a looping.
But could you please tell me how?
I mean, which commands, how the looping would work?
Just a sample would help me. Thanks so much!
int timesMAX = 20; // 20 x 8 seconds
int currentCount = 0;
After wake increment currentCount
Check if it is == timesMAX
if it is
do stuff
reset the currentCount = 0
sleep again
Hint: study this excellent tutorial on low power operation.
