Could you help me with this code? My motors don't seem to move at all.
//AUTOMATIC BOARD ERASER
// As the title suggests, I am working on a project for a board eraser
// It consists of an RC Car moving back and forth atop a rack placed on top of the board
// It is triggered by two push button switches (Pull up resistors) places on front and back
// This is my humble attempt at the code. I am a novice programmer, kindly ignore the indentation faults
#include <AFMotor.h>
AF_DCMotor motor1(1); //DC Motors on AdaFruit board
AF_DCMotor motor2(4);
char on_off = '0'; //initialising the char for on and off switch
int buttonPin1 = 15; //My pin buttons as adafruit analog pins aren't used,
int buttonPin2 = 16; //I used them as my digital pins for signals from pushbutton switches 15 and 16
boolean SwitchDeBounce1_1 = LOW,SwitchDeBounce2_1 = LOW, SwitchDeBounce3_1 = LOW; //Debouncing for Pin1
boolean SwitchDeBounce1_2 = LOW,SwitchDeBounce2_2 = LOW, SwitchDeBounce3_2 = LOW; //Debouncing for Pin2
boolean newSwitchState1 = LOW,oldSwitchState1 = LOW ; //switch states to detect a if a button is pressed
boolean newSwitchState2 = LOW, oldSwitchState2 = LOW;
int buttonTrigger = 0; //To keep track of which command to execute on a button press
void motorOff()
motor1.run(RELEASE);
motor2.run(RELEASE);
newSwitchState1 = LOW,newSwitchState2 = LOW ; //re-initialisation of variables
oldSwitchState1 = LOW, oldSwitchState2 = LOW;
void backward()
motor1.run(BACKWARD);
motor2.run(BACKWARD);
void forward()
motor1.run(FORWARD);
motor2.run(FORWARD);
void pause()
pinMode(buttonPin1,INPUT); //button Pin1 (front) set to input
pinMode(buttonPin2,INPUT); //button Pin2 (back) set to input
motor1.setSpeed(255);
motor2.setSpeed(255);
motorOff();
if(Serial.available() > 0)
on_off = Serial.read(); //Read the incoming bluetooth data and set the on/off state
if(on_off == '1')
motorOn();
motorOff();
void motorOn()
//Debouncing part for pin1
SwitchDeBounce1_1 = digitalRead(buttonPin1);
delay(1);
SwitchDeBounce2_1 = digitalRead(buttonPin1);
delay(1);
SwitchDeBounce3_1 = digitalRead(buttonPin1);
delay(1);
if( (SwitchDeBounce1_1 == SwitchDeBounce2_1) && (SwitchDeBounce1_1 == SwitchDeBounce3_1) ) //After the switch has steadied
newSwitchState1 = SwitchDeBounce1_1; //set the switch state value to the one read
if( newSwitchState1 != oldSwitchState1 ) //if there is a detection of button press
if (newSwitchState1 == HIGH) //if the button is pressed
backward();
buttonTrigger = 1; //button trigger set to 1 to go backward as the front pushbutton is pressed
if(buttonTrigger == 0)
forward();
else if (buttonTrigger == 1)
backward();
oldSwitchState1 = newSwitchState1; //switch state updated to detect the next button press
//Debouncing part for pin2, the rest of the code is similar except that I have added a pause and a delay of 5s before the bot starts moving again
SwitchDeBounce1_2 = digitalRead(buttonPin2);
delay(1);
SwitchDeBounce2_2 = digitalRead(buttonPin2);
delay(1);
SwitchDeBounce3_2 = digitalRead(buttonPin2);
delay(1);
if( (SwitchDeBounce1_2 == SwitchDeBounce2_2) && (SwitchDeBounce1_2 == SwitchDeBounce3_2) )
newSwitchState2 = SwitchDeBounce1_2;
if ( newSwitchState2 != oldSwitchState2 )
if(newSwitchState2 == HIGH)
pause();
buttonTrigger = 2;
if(buttonTrigger == 1)
backward();
else if(buttonTrigger == 2)
delay(5000);
forward();
buttonTrigger = 0;
oldSwitchState2 = newSwitchState2;
Your Title says "My motors don't seem to move at all."
Have you been able to get the motors to work with a much shorter program that does nothing other than make the motors work?
If not, then that is the place to start.
On the other hand if you do have a short program that makes the motors work then how does it differ from the program in which the motors don't work?
...R
Sorry. No can do. Indentation is key to structuring your code in a readable way. There's an auto-format tool available in the Arduino IDE. (Maybe not in the web version though.) USE IT. If it appears to scramble your code then the code was wrong.
Then you must use code tags to post code. The forum software eats some of your code if you don't. You may edit your post.
