Could you look over some code?
This is the original code. I didn’t write this and is not mine.
#include <Servo.h>     // includes the servo libs
Servo LeftServo;       // name the servo
Servo RightServo;      // name the servo
int ultraSoundSignal = 7; // Ultrasound signal pin
int val = 0;
int val2 = 0;
int ultrasoundValue = 0;
int timecount = 0; // Echo counter
int ledPin = 13; // LED connected to digital pin 13
int lightSense = 2;
int headLight = 8;
void setup(){
   pinMode(6,OUTPUT);
   pinMode(5,OUTPUT);
   LeftServo.attach(6);	 // Attaches the Left Servo to PWM pin 6 on the Arduino
   RightServo.attach(5); // Attaches the Right Servo to PWM pin 5 on the Arduino
   pinMode(headLight, OUTPUT);
   pinMode(lightSense, INPUT);
   beginSerial(9600);                  // Sets the baud rate to 9600
   pinMode(ledPin, OUTPUT);            // Sets the digital pin as output
void moveServoLeftTo(int angle, int duration){
  // command the servo to move to the given angle for the given number of milliseconds
   LeftServo.write(angle);
   for( ; duration > 0; duration -= 20){  // loop for the given number of milliseconds by subtracting 20ms each iteration
	 LeftServo.refresh();             // call the service routine to move the servo
	 delay(20);		          // wait 20 milliseconds  between each refresh
void moveServoRightTo(int angle, int duration){
   RightServo.write(angle);
	 RightServo.refresh();            // call the service routine to move the servo
 // Ping))) functions: Doing more than I need it to, I think, but code
 timecount = 0;
 val = 0;
 pinMode(ultraSoundSignal, OUTPUT);   // Switch signalpin to output
  digitalWrite(ultraSoundSignal, LOW);  // Send low pulse
  delayMicroseconds(2);                 // Wait for 2 microseconds
  digitalWrite(ultraSoundSignal, HIGH); // Send high pulse
  delayMicroseconds(5);                 // Wait for 5 microseconds
  digitalWrite(ultraSoundSignal, LOW);  // Holdoff
  pinMode(ultraSoundSignal, INPUT);     // Switch signalpin to input
  val = digitalRead(ultraSoundSignal);  // Append signal value to val
  while(val == LOW) {                   // Loop until pin reads a high value
  while(val == HIGH) {                  // Loop until pin reads a high value
  timecount = timecount +1;           // Count echo pulse time
ultrasoundValue = timecount;          // Append echo pulse time to ultrasoundValue
if(timecount > 0){
  digitalWrite(ledPin, HIGH);
//delay(1);
// Servo functions: The basics
  if(ultrasoundValue > 500){
	moveServoLeftTo(45,50);   // move the left servo to 45 degrees for 500 milliseconds
	moveServoRightTo(180,50);  // moveRightTo function is left as an excercise ;)
  if(ultrasoundValue < 500){
      moveServoLeftTo(180,40);
      moveServoRightTo(180,40);
     if(ultrasoundValue < 100){
      moveServoLeftTo(180,100);
      moveServoRightTo(45,100);
      //moveServoLeftTo(45,50);
      //moveServoRightTo(180,50);
// Headlight - Turns on when photoresistor is triggered
// Doesn't seem to work on the same circuit... not sure why yet.
/*  val2 = digitalRead(lightSense);  // read input value
  if (val == HIGH) {            // check if the input is HIGH
    digitalWrite(headLight, LOW);  // turn LED OFF
    digitalWrite(headLight, HIGH); // turn LED ON
I was told that this is older code and that I would not need  RightServo.refresh();. Is there any thing similar to that, so I could refresh the servos.
This is what I have done to it.
Servo LeftServo1;       // name the servo
Servo RightServo2;      // name the servo
int val = 0;
int val2 = 0;
int lightSense = 2;
int headLight = 8;
void setup(){
   pinMode(6,OUTPUT);
   pinMode(5,OUTPUT);
   LeftServo1.attach(6);	 // Attaches the Left Servo to PWM pin 6 on the Arduino
   RightServo2.attach(5); // Attaches the Right Servo to PWM pin 5 on the Arduino
   Serial.begin(9600);                  // Sets the baud rate to 9600
   LeftServo1.write(angle);
   for (; 2 > 0; 60 - 20){  // loop for the given number of milliseconds by subtracting 20ms each iteratio
   RightServo2.write(angle);
   for( ; 2 > 0; 60 - 20){  // loop for the given number of milliseconds by subtracting 20ms each iteration
 timecount = 0;
 val = 0;
if(timecount > 0){
//delay(1);
What could I do to make this code work better?
You don't need to do anything. Servo.write() sets the position of the servo. The library 'refreshes' for you.
Thanks for the info, if you see anything else could you tell me? I am looking to improve this code.
You need to look at http://arduino.cc/en/Reference/For and then look at this:
paying particular attention to the conditional part.
Not sure why you started another thread though. It seems to relate to your other one.
