couldn't find fona
FONA basic test
Initializing…(May take several seconds)
Configuring to 4800 baud
Attempting to open comm with ATs
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
—> AT
Timeout: No response to AT… last ditch attempt.
—> AT
—> AT
—> AT
—> ATE0
—> ATE0
Couldn’t find FONA
I don’t know what’s the problem here can anyone help me with this?
I don't know what's the problem here can anyone help me with this?
I can see nothing wrong with the code that you did not post
#include “Adafruit_FONA.h”
#define SIMCOM_7000 // SIM7000A/C/E/G
#define FONA_PWRKEY 6
#define FONA_RST 7
#define FONA_TX 10 // Microcontroller RX
#define FONA_RX 11 // Microcontroller TX
// this is a large buffer for replies
char replybuffer[255];
#include <SoftwareSerial.h>
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
buffer size
SoftwareSerial *fonaSerial = &fonaSS;
#ifdef SIMCOM_2G
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
// Use this one for 3G modules
#elif defined(SIMCOM_3G)
Adafruit_FONA_3G fona = Adafruit_FONA_3G(FONA_RST);
#elif defined(SIMCOM_7000) || defined(SIMCOM_7500)
Adafruit_FONA_LTE fona = Adafruit_FONA_LTE();
#endif
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
uint8_t type;
char imei[16] = {0}; // MUST use a 16 character buffer for IMEI!
// while (!Serial);
pinMode(FONA_RST, OUTPUT);
digitalWrite(FONA_RST, HIGH); // Default state
pinMode(FONA_PWRKEY, OUTPUT);
powerOn(); // See function definition at the very end of the sketch
Serial.println(F(“FONA basic test”));
Serial.println(F(“Initializing…(May take several seconds)”));
fona.setNetworkSettings(F(“hologram”)); // For Hologram SIM card
fonaSS.begin(115200); // Default SIM7000 shield baud rate
Serial.println(F(“Configuring to 4800 baud”));
fonaSS.println(“AT+IPR=4800”); // Set baud rate
fonaSS.begin(4800);
if (! fona.begin(fonaSS)) {
Serial.println(F(“Couldn’t find FONA”));
while(1); // Don’t proceed if it couldn’t find the device
I don’t know what might be the problem can you help me ?
Hi, I know this topic is old, but just in case.
Did you solve the problem? In that case, I'd appreciate you telling me about the solution.
Thanks,
Hi I have a similar problem, I am running SIM7000C and based in NZ. I have a 2-Degrees Simcard on my LTE. It is giving no errors except for:
11:53:57.426 → Timeout: No response to AT… last ditch attempt.
11:53:57.464 → —> AT
11:53:57.954 → <—
11:53:58.097 → —> AT
11:53:58.610 → <—
11:53:58.752 → —> AT
11:53:59.291 → <—
11:53:59.430 → —> ATE0
11:53:59.919 → <—
11:54:00.092 → —> ATE0
11:54:00.585 → <—
11:54:00.623 → Couldn’t find FONA
Someone please help
