Couldnt understand the error in compilation
Couldnt understand the errror in compilation ,please help
int led1=2;
pinMode(led1,OUTPUT);// put your setup code here, to run once:
int sensorValue1=analogRead(A1);
if (sensorValue1>=600&& sensorValue1<=800){
Serial.printIn(sensorValue1);
digitalWrite(led1,HIGH);// put your main code here, to run repeatedly:
else{
digitalWrite(led1,LOW);
int sensorValue2=analogRead(A2);
if (sensorValue2>=600&& sensorValue2<=800){
serial.printIn(sensorValue2);
else{
Serial.printIn(sensorValue2);
error message:exit status 1
‘class HardwareSerial’ has no member named ‘printIn’
electwetfdetectcode.ino (621 Bytes)
You didn't post the errror.
Or the code.
If you want help, then post your code using code tags (the </> button in the top left corner) instead of attaching it. Also copy the error message and post it here.
Wrong
Wrong
Wrong
Double Wrong
Check this out Serial.println()
Check you code for the lines above [u]very[/u] carefully against the reference page
