Count of the number of integers entered and the running sum
Hi, new to coding and hope to get some help. Here is the code provided to me:
int readIntFromSerialWithEnter() {
  byte ndx ;
  const char endMarker = '\n';
  const byte numChars = 32 ;
  char receivedChars[numChars] ;
  char rc;
  ndx = 0 ;
  while ( true) {                    // loop forever until a return breaks out of function
    while(Serial.available() == 0) ; // hang waiting on next serial data
    rc = Serial.read();              // read the next char
    if (rc != endMarker) {           // if enter was not pressed
       receivedChars[ndx] = rc;      // add the char to the string array
       ndx++;                        // increment the index into the array
       if (ndx >= numChars) ndx = numChars - 1; // this is a hack way of preventing overflow of char array
     else {                          // enter was pressed
       receivedChars[ndx] = '\0';    // terminate the string
       return atoi(receivedChars) ;  // convert to integer and return
  Serial.begin(9600);   // set serial port up, use 9600 bps
  int val ;     // this is the integer that the read integer is returned to
  Serial.println("Enter a number in the box on the serial monitor.") ; // this prompts for the user to enter a number
  val=readIntFromSerialWithEnter() ;
  Serial.print("The integer you entered is ") ;
  Serial.println(val) ;
The code provided waits for an integer to be entered in the serial monitor and outputs the exact integer. My goal is to modify the loop code so that every time an integer is entered, a count of the number of integers entered so far, a running sum, and the average (sum/count) is the output. For example, suppose the number 3, 6, 9 have been entered so far, I should get count=3, sum=18, average=6 as my output.
I tried declare int count and int sum inside void loop and do count=++count and sum=sum+=val, but it doesn't seem to work. Any help is appreciated and thank you for your time.
Your code is incomplete
Can you please elaborate on that? Also I attached the code given to me if that helps.
template-SerialSum.ino (2.94 KB)
I can't see what you tried.
ewirbgied:
The code you posted is missing at least a final }, possibly more
No, that doesn't help at all because my phone doesn't open .ino files.
The Serial library has a ".parseInt()" function which will read a number. It's only problem is that if it times out (doesn't see a character for one full second) it returns 0. By making sure that the next character is the start of a number before calling .parseInt() you can be sure that it won't return 0 unless the number is 0. Here is how you might do that:
unsigned int Count = 0;
long int Sum = 0;
  Serial.begin(115200);   // set serial port up, use 9600 bps
  if (Serial.available())
    // Is the next character the start of a number?
    if (isDigit(Serial.peek()) || Serial.peek() == '-')
      // Yes!  Read the number
      long int number = Serial.parseInt();  // Read the number until a non-digit or timeout.
      Count++;
      Sum += number;
      Serial.print("Read number ");
      Serial.print(number);
      Serial.print(" making the count ");
      Serial.print(Count);
      Serial.print(" and the sum ");
      Serial.println(Sum);
      // Not the start of a number so just throw away this character
      Serial.read();
