misi89
August 5, 2018, 1:43pm
#1
Hi.
I have a project where I have a servo which should change its position from 80° to 140° and back to 80° 4times. What is important I can not use delay in the code.
I tried in many ways, and all worked for continuous ‘sweep’ but I can not count the cycles.
Basically I have an RTC that provides time and in a certain time it calls the servo function that should do 4 sweeps from 80° → 140° → 80°.
I tried with a for loop then do…while cycle with no success. Coud you give me few tips? Thank you.
Code only for the servo:
#include <Servo.h>
Servo myservo;
int myservo_pin = 17;
long myservo_movetime = 50;
int pos = 80;
int cPos;
int gPos;
int tDelay = 10;
myservo.attach(myservo_pin);
cPos = myservo.read();
if (cPos == 80) gPos = 140;
if (cPos == 140) gPos = 80;
if (cPos != gPos && millis() >= myservo_movetime) moveServo();
void moveServo() {
if (cPos < gPos) myservo.write(cPos+1);
if (cPos > gPos) myservo.write(cPos-1);
myservo_movetime = millis() + tDelay;
Something to experiment with
#include <Servo.h>
Servo theServo;
byte sweepCount;
const byte servoPin = A5;
int servoIncrement = 1;
byte servoPos = 80;
boolean moving = false;
unsigned long waitStartTime;
unsigned long currentTime;
unsigned long stepPeriod = 10;
const byte buttonPin = A1; //for testing purposes
theServo.attach(servoPin);
pinMode(buttonPin, INPUT_PULLUP);
currentTime = millis();
if (moving == false)
if (digitalRead(buttonPin) == LOW)
moving = true;
if (currentTime - waitStartTime >= stepPeriod) //time to move
theServo.write(servoPos);
servoPos += servoIncrement;
if (servoPos < 80 || servoPos > 140)
servoIncrement *= -1;
sweepCount++;
if (sweepCount == 8)
moving = false;
sweepCount = 0;
waitStartTime = currentTime;
//other non blocking code can be put in loop()
In this program the servo sweeps are started with a button press but you could start them with any other required trigger.
misi89
August 5, 2018, 7:08pm
#3
Thank you. Exactly this is what I was looking for, In the meantime I figured out a workaround, but your solution looks better.
Thank you.
What would be even better would be a state machine controlled by switch/case with 3 states. It would be more obvious what was happening
misi89
August 6, 2018, 6:48am
#5
Thank you very much. I will look forward to it and implement in the next variant.
A state machine version
#include <Servo.h>
Servo theServo;
byte sweepCount;
unsigned long stepStartTime;
const byte lowerLimit = 80;
const byte upperLimit = 140;
byte servoPos = lowerLimit;
const byte triggerPin = A1; //for testing purposes
enum states
WAITING_FOR_TRIGGER,
INCREASE_ANGLE,
DECREASE_ANGLE
byte currentState = WAITING_FOR_TRIGGER;
pinMode(triggerPin, INPUT_PULLUP);
switch (currentState)
case WAITING_FOR_TRIGGER:
if (digitalRead(triggerPin) == LOW)
stepStartTime = currentTime;
currentState = INCREASE_ANGLE;
sweepCount = 0;
case INCREASE_ANGLE:
if (currentTime - stepStartTime >= stepPeriod)
if (servoPos > upperLimit)
servoPos = upperLimit;
currentState = DECREASE_ANGLE;
case DECREASE_ANGLE:
servoPos -= servoIncrement;
if (servoPos < lowerLimit)
sweepCount++;
if (sweepCount == 4)
