Count steps with Tilt Switch Pedometer?
Is it possible to use a tilt switch to count steps like a pedometer?
I am using a tilt switch at the moment but it is always HIGH so it always adds to a counter no matter where it is positioned.
Thanks Joe
It should work just fine, provided it is wired correctly and a proper sketch is run.
To firure out why it isn't working we need to see schematics, sketch, and possibly a picture of how it is arranged.
living on a hillside ? ;)
Apart from the point that you have probably wired it up incorrectly, you should be look for edges not levels. In other words you should only increment on a change not on a level.
