Count the number of rising edges
I want to count the number of rising edges on the A encoder signals coming out form the motor between two rising edges of the z encoder pulse. My code is as below,
int countA = 0;
pinMode(2, INPUT); //z encoder
pinMode(3, INPUT); //A encoder
attachInterrupt(digitalPinToInterrupt(2), doEncoder, RISING);
Serial.println("start");
void loop(){
void doEncoder()
for (digitalRead(2) == HIGH) {
if (digitalRead(3) == HIGH) {
countA = countA + 1;
}Serial.println(countA, DEC);
May i know what's wrong with the code as it won't stop counting the positive edge on encoder A. I only want it to count once when there is a rising edge of z encoder.
Thanks.
Do not output to Serial inside an interrupt handler. Serial IO requires use of interrupts, which are blocked while a handler is running.
The pattern to use is:
volatile boolean something_just_happened = false;
volatile int some_important_number;
void interruptHandler() {
  some_important_number ++;
  something_just_happened = true;
  // check the status of the interrupt stuff
  // the *only* thing that happens in this section of code is that we
  // retreive the values that the interrupt handler updates
  // and reset them as needed
  noInterrupts();
  int important_number_copy;
  boolean something_just_happened_copy = something_just_happened;
  if(something_just_happened) {
    important_number_copy =   some_important_number;
    some_important_number = 0; // reset the count
    something_just_happened = false; // reset the flag
  interrupts();
  // end of the nointerrupts block. Now we examine the data that we just retrieved
  // and potentially do something with it
  if(something_just_happened_copy) {
    Serial.print("There were ");
    Serial.print(important_number_copy);
    Serial.println(" ticks");
Which pin is the z encoder connected to? Where are you detecting the RISING edge of that pin? The only thing I see you doing is determining if pin 3 IS high (not BECAME high).
It's pretty dumb to check that pin 2 is HIGH in the ISR. The ISR would not have been called unless pin 2 just went HIGH.
Serial.print() has no place in an interrupt handler.
htliew:
What do you suppose that 'for' does? Perhaps you meant 'while' ?
htliew:
int countA = 0;
void loop(){
void doEncoder()
Thanks.
Just curious - how does the above code compile? The complier should generate syntax error on incorrect "for(...)".
The code would be much simpler, less variables, if you gate in the ISR on z first then advance the "new rising edge " counter.
if(z)
new rising edge counter++
then in loop() compare new and old rising edge counter and if different do your processing.
But .. you will need a code to monitor the z "pulse" window , perhaps add an ISR for z also.
Time to draw a flow chart before coding.
