count the rotation of the encoders
hi,
i have robot-rover 5, and i didnt succeed to count right the rotation of the wheels.
its actually count but count wrong,
this is the code that i use:
Code:
// Dagu 5 Chassis example.
// Author: Nick Gammon
// Date: 11th December 2011
volatile int rotaryCount = 0;
#define PINA 8
#define PINB 9
#define INTERRUPT 0 // that is, pin 2
#define DIRECTIONA 4
#define MOTORA 5
#define DIRECTIONB 7
#define MOTORB 6
#define TIME_FORWARDS 10000
#define TIME_BACKWARDS 10000
#define TIME_TURN 1200
// Interrupt Service Routine for a change to encoder pin A
void isr ()
boolean up;
if (digitalRead (PINA))
up = digitalRead (PINB);
up = !digitalRead (PINB);
if (up)
rotaryCount++;
rotaryCount–;
} // end of isr
void setup ()
attachInterrupt (INTERRUPT, isr, CHANGE); // interrupt 0 is pin 2, interrupt 1 is pin 3
pinMode (MOTORA, OUTPUT);
pinMode (DIRECTIONA, OUTPUT);
pinMode (MOTORB, OUTPUT);
pinMode (DIRECTIONB, OUTPUT);
} // end of setup
byte phase;
unsigned long start;
int time_to_go;
void loop ()
analogWrite (MOTORA, 200);
analogWrite (MOTORB, 200);
start = millis ();
// check current drain
while (millis () - start < time_to_go)
if (analogRead (0) > 325) // > 1.46 amps
switch (phase++ & 3)
case 0:
digitalWrite (DIRECTIONA, 1);
digitalWrite (DIRECTIONB, 1);
time_to_go = TIME_FORWARDS;
case 1:
// turn
digitalWrite (DIRECTIONB, 0);
time_to_go = TIME_TURN;
case 2:
digitalWrite (DIRECTIONA, 0);
time_to_go = TIME_BACKWARDS;
case 3:
} // end of switch
analogWrite (MOTORA, 0);
analogWrite (MOTORB, 0);
delay (500);
} // end of loop
I am not an expert, but from what I have read, you may need to use debounce to get a true reading. In addition are you using a pull-up resistor to insure you are in a guaranteed condition for your readings?
Just a couple thoughts...
