count vehicle
hello i'm rod
i'm currently working on a project which involve counting vehicles
but first i'm trying to test it on a smaller scale prototype.
i'm using ultrasonic sensors (HC-SR04)
I got a code working to count, but i'm trying to simulated when ever the scenario involve a car park in front of the sensor, the count increment until the object move out of the sensor.
I was wondering if y'all know any kind of algorithm to try it on my code to cancel the increment of counts while a vehicle is stationary in front of the sensor, or any ideas would be help full
this is my code
#define trigPin 13
#define echoPin 12
int counter = 0; //Initialize the counter
int currentState = 0; //Initialize the current state
int previousState = 0; //Initialize the previous state
int parkedCar = 0;//Parked car variable
Serial.begin(9600);// Initialize serial communication
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance <= 30){
currentState = 1;
else {
currentState = 0;
if (trigPin == LOW){
parkedCar = 1;
else {
parkedCar = 0;
delay(300); //Delay for counter
if(currentState != previousState){
if(currentState == 1 && (parkedCar == 0)){
counter = counter + 1;
Serial.println(counter);
/*if(currentState != previousState){
if(currentState = 1){
if(parkedCar = 1){
Thanks for y'all time
Your if() statements are wrong. They are doing an assignment '=' when they should be doing an equality comparison '=='
Look at the StateChangeDetection example.
A concept using a state machine.
(No attempt made to compile nor test. Just a basic framework to give you ideas.)
#define trigPin 13
#define echoPin 12
}//setup
//statemachine state names
#define WAIT_FOR_VEHICLE    0
#define WAIT_FOR_NO_VEHICLE 1
    static byte
        state = WAIT_FOR_VEHICLE;   //start with waiting for a vehicle
    float
        dist;
    switch( state )
        case    WAIT_FOR_VEHICLE:
            //get the distance...
            dist = MeasureDistance();
            //...if it's less than 30cm and greater than zero (pulseIn returns 0 if no pulse seen...)...
            if(  dist <= 30.0 && dist > 0.0 )
                //bump the count then move to the state where we wait for the sensor to show
                //clear again
                counter++;
                Serial.print( F("Count is: ") );
                Serial.println( counter );
                state = WAIT_FOR_NO_VEHICLE;
            }//if
        case    WAIT_FOR_NO_VEHICLE:
            //sensor must show something >40cm away (or show ~0.0) before we say the coast is clear
            //I used 0.01 instead of "==0.0" in case the math returns a float that's tiny but not
            //_equal_ to zero.
            if(  dist > 40.0 || dist <= 0.01 )
                //when condition met, go back to waiting for vehicle again
    }//switch
}//loop
float MeasureDistance( void )
    unsigned long
        duration;
    return( (float)duration/2.0) / 29.1;
}//MeasureDistance
