Countdown Timer doesn´t show numbers
Hi all!
I've been working on a project for a countdown counter that works with neopixel LEDs and an RTC DS3231, all this on an arduino nano.
The problem comes when I have tried to add the RTC to the new code, which works perfectly and in the serial monitor it does show what I want but when I look at the NEOPIXEL they don't show anything similar.
So I need some help if anyone can see or can help me with solving this problem.
I'll add the code that worked perfectly without RTC and the code that doesn't work with RTC so that you can compare it.
This is the code without RTC:
#define PIN 10 // the pin your strip is connected to
#define COUNT 396 // how many led's are on that strip
Adafruit_NeoPixel strip = Adafruit_NeoPixel(COUNT, PIN, NEO_RGB + NEO_KHZ800); //defines the strips properties
void setColor(int Pixel, int R2, int G2, int B2) {
  uint32_t color = strip.Color(R2, G2, B2); // make a color
  strip.setPixelColor(Pixel, color); //set a single pixel color
  //update the colors
int col;
int A, M, D, H, m, s;
bool cuenta = 1;
bool digito[10][36] =
  { //0
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0, 0
  { //1
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0, 0
  { //2
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1, 0
  { //3
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1, 0
  { //4
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //5
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //6
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //7
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0, 0
  { //8
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //9
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  strip.begin();
  strip.show();
  strip.clear();
  A = 1;
  M = 0;
  D = 0;
  H = 0;
  m = 1;
  s = 10;
  if (cuenta = 1) {
    s--;
    if (s < 0) {
      s = 59;
      m--;
      if (m < 0) {
        m = 59;
        H--;
        if (H < 0) {
          H = 23;
          D--;
          if (D < 0) {
            D = 31;
            M--;
            if (M < 0) {
              M = 12;
              A--;
              if (A < 0) {
                A = 0;
                M = 0;
                D = 0;
                H = 0;
                m = 0;
                s = 0;
                cuenta = 0;
  Serial.print(A);
  Serial.print("/");
  Serial.print(M);
  Serial.print("/");
  Serial.print(D);
  Serial.print("  // ");
  Serial.print(H);
  Serial.print(":");
  Serial.print(m);
  Serial.print(":");
  Serial.print(s);
  Serial.print("");
  Serial.println("");
  pd(0, A);
  pd(1, M / 10);
  pd(2, M % 10);
  pd(3, D / 10);
  pd(4, D % 10);
  pd(5, H / 10);
  pd(6, H % 10);
  pd(7, m / 10);
  pd(8, m % 10);
  pd(9, s / 10);
  pd(10, s % 10);
  delay(990);
void pd(int k, int j) {
  for (int i = 0 ; i < 36; i++ ) {
    col = digito[j][i] * 255;
    setColor(i + (k * 36), 0, col, 0);
  strip.show();
And this is the code with RTC
#include <Wire.h>
#include <RTClib.h>
RTC_DS3231 rtc;
  //update the colors
bool cuenta = 1;
int col;
//DateTime now = rtc.now();
bool digito[10][37] =
  { //0
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0, 0
  { //1
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0, 0
  { //2
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1, 0
  { //3
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1, 0
  { //4
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //5
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //6
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //7
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0, 0
  { //8
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //9
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  strip.begin();
  //strip.begin ();
 // strip.show();
 // strip.clear();
  rtc.begin();
  Wire.begin();
  // rtc.adjust(DateTime(F(__DATE__),F(__TIME__)));
  // delay(1000);
  strip.show();
  strip.clear();
  A = now.year() - 2021;
  M = - now.month() + 10;
  D = - now.day() + 31;
  H = 24 - now.hour();
  m = 60 - now.minute() ;
  s = 59 - now.second();
  if (cuenta = 1) {
    s--;
    if (s < 0) {
      s = 59;
      m--;
      if (m < 0) {
        m = 59;
        H--;
        if (H < 0) {
          H = 23;
          D--;
          if (D < 0) {
            D = 31;
            M--;
            if (M < 0) {
              M = - 12;
              A--;
               if (A < 0) {
                A = 0;
                M = 0;
                D = 0;
                H = 0;
                m = 0;
                s = 0;
                cuenta = 0;
    pd(0, A);
  pd(1, M / 10);
  pd(2, M % 10);
  pd(3, D / 10);
  pd(4, D % 10);
  pd(5, H / 10);
  pd(6, H % 10);
  pd(7, m / 10);
  pd(8, m % 10);
  pd(9, s / 10);
  pd(10, s % 10);
  Serial.print(A);
  Serial.print("/");
  Serial.print(M);
  Serial.print("/");
  Serial.print(D);
  Serial.print(H);
  Serial.print(":");
  Serial.print(m);
  Serial.print(":");
  Serial.print(s);
  Serial.print("");
  Serial.println("");
 // pd(0, A);
 // pd(1, M / 10);
 // pd(2, M % 10);
// pd(3, D / 10);
  //pd(4, D % 10);
  //pd(5, H / 10);
  //pd(6, H % 10);
 // pd(7, m / 10);
 // pd(8, m % 10);
  //pd(9, s / 10);
  //pd(10, s % 10);
  delay (1000);
    setColor(i + (k * 36), 0, 0, 255);
   // strip.setPixelColor (i, 255, 255, 255);
 strip.show();
 //strip.clear();
I doubt it
  if (cuenta = 1)
This sets cuenta to 1 every time through loop(). I expect you meant
  if (cuenta == 1)
Yesi meant that, i saw i have some errors , sorry
If you have made changes to the code then please post the new code here in a new post here. If you have errors when compiling then post the full error messages here in code tags
I changed it but it diddn´t solve it anything
HINT : we can't see the code that you changed
It didn´t solved nothing because the problem comes when i try to add the RTC module, before that it works.
But i have changed the code so you can see it better.
Thanks!
#include <Wire.h>
#include <RTClib.h>
RTC_DS3231 rtc;
  //update the colors
bool cuenta = 1;
int col;
  { //0
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0, 0
  { //1
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0, 0
  { //2
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1, 0
  { //3
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1, 0
  { //4
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //5
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //6
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //7
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0, 0
  { //8
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //9
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  Serial.begin(57600);
  strip.begin();
  //strip.begin ();
 // strip.show();
 // strip.clear();
  rtc.begin();
  Wire.begin();
  // delay(1000);
  strip.show();
  strip.clear();
  if (cuenta == 1) {
    s--;
    if (s < 0) {
      s = 59;
      m--;
      if (m < 0) {
        m = 59;
        H--;
        if (H < 0) {
          H = 23;
          D--;
          if (D < 0) {
            D = 31;
            M--;
            if (M < 0) {
              M = - 12;
              A--;
              if (A < 0) {
                A = 0;
                M = 0;
                D = 0;
                H = 0;
                m = 0;
                s = 0;
                cuenta == 0;
    pd(0, A);
  pd(1, P / 10);
  pd(2, P % 10);
  pd(3, P / 10);
  pd(4, P % 10);
  pd(5, H / 10);
  pd(6, H % 10);
  pd(7, m / 10);
  pd(8, m % 10);
  pd(9, s / 10);
  pd(10, s % 10);
  Serial.print(A);
  Serial.print("/");
  Serial.print(M);
  Serial.print("/");
  Serial.print(D);
  Serial.print(H);
  Serial.print(":");
  Serial.print(m);
  Serial.print(":");
  Serial.print(s);
  Serial.print("");
  Serial.println("");
 // pd(0, A);
 // pd(1, M / 10);
 // pd(2, M % 10);
// pd(3, D / 10);
  //pd(4, D % 10);
  //pd(5, H / 10);
  //pd(6, H % 10);
 // pd(7, m / 10);
 // pd(8, m % 10);
  //pd(9, s / 10);
  //pd(10, s % 10);
  delay (990);
   col = digito[j][k] * 255;
   // strip.setPixelColor (i, 0, 255, 255);
 strip.show();
                cuenta == 0;
Wrong
This does not set cuenta to zero. It compares cuenta to zero and throws away the result
                cuenta == 0;
This is still in the code and is still wrong
sorry i thought I changed it.
Heres the code right now:
#include <Wire.h>
#include <RTClib.h>
RTC_DS3231 rtc;
  //update the colors
bool cuenta = 1;
int col;
  { //0
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0, 0
  { //1
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0, 0
  { //2
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1, 0
  { //3
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1, 0
  { //4
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //5
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //6
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //7
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0,
    0, 0, 0, 0, 0, 0
  { //8
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  { //9
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1,
    0, 0, 0, 0, 0,
    1, 1, 1, 1, 1,
    1, 1, 1, 1, 1, 0
  strip.begin();
  //strip.begin ();
 // strip.show();
 // strip.clear();
  rtc.begin();
  Wire.begin();
  // delay(1000);
  strip.show();
  strip.clear();
  if (cuenta == 1) {
    s--;
    if (s < 0) {
      s = 59;
      m--;
      if (m < 0) {
        m = 59;
        H--;
        if (H < 0) {
          H = 23;
          D--;
          if (D < 0) {
            D = 31;
            M--;
            if (M < 0) {
              M = - 12;
              A--;
              if (A < 0) {
                A = 0;
                M = 0;
                D = 0;
                H = 0;
                m = 0;
                s = 0;
                cuenta == 0;
    pd(0, A);
  pd(1, P / 10);
  pd(2, P % 10);
  pd(3, P / 10);
  pd(4, P % 10);
  pd(5, H / 10);
  pd(6, H % 10);
  pd(7, m / 10);
  pd(8, m % 10);
  pd(9, s / 10);
  pd(10, s % 10);
  Serial.print(A);
  Serial.print("/");
  Serial.print(M);
  Serial.print("/");
  Serial.print(D);
  Serial.print(H);
  Serial.print(":");
  Serial.print(m);
  Serial.print(":");
  Serial.print(s);
  Serial.print("");
  Serial.println("");
 // pd(0, A);
 // pd(1, M / 10);
 // pd(2, M % 10);
// pd(3, D / 10);
  //pd(4, D % 10);
  //pd(5, H / 10);
  //pd(6, H % 10);
 // pd(7, m / 10);
 // pd(8, m % 10);
  //pd(9, s / 10);
  //pd(10, s % 10);
  delay (990);
 strip.show();
But the problem is that the neopixels doesn´t react to the code that has integrated the RTC module. Buf if i use the other without RTC it works
                cuenta == 0;
Please stop messing about and correct this
Please describe what the code is supposed to do and what it actually does
