countdown timer keeps resetting
Hi guys,
Im making a little project that uses an Arduino Nano and a rotary encoder.
The encoder sets the time and its push button starts it.
I borrowed the countdown code from here mostly Arduino Playground- CountDownTimer
I can set the timer and get it to countdown but if i set the timer for say 10 seconds and it elapses and i wait maybe 3 seconds and press the button again the serial terminal will show the count at about 7 seconds.
Im maybe missing something very obvious but would someone be so kind as to put me out of my misery.
Thanks, Much appreciated.
unsigned long Watch, _micro, time = micros();
unsigned int Clock = 0, R_clock;
boolean Reset = false, Stop = false, Paused = false;
volatile boolean timeFlag = false;
int started =0;
int buttonPIN =4;
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
static int pinA = 2; // Our first hardware interrupt pin is digital pin 2
static int pinB = 3; // Our second hardware interrupt pin is digital pin 3
volatile byte aFlag = 0; // let's us know when we're expecting a rising edge on pinA to signal that the encoder has arrived at a detent
volatile byte bFlag = 0; // let's us know when we're expecting a rising edge on pinB to signal that the encoder has arrived at a detent (opposite direction to when aFlag is set)
volatile byte encoderPos = 1; //this variable stores our current value of encoder position. Change to int or uin16_t instead of byte if you want to record a larger range than 0-255
volatile byte oldEncPos = 0; //stores the last encoder position value so we can compare to the current reading and see if it has changed (so we know when to print to the serial monitor)
volatile byte reading = 0; //somewhere to store the direct values we read from our interrupt pins before checking to see if we have moved a whole detent
uint16_t h;
uint8_t m;
uint8_t s;
void PinA(){
  cli(); //stop interrupts happening before we read pin values
  reading = PIND & 0xC; // read all eight pin values then strip away all but pinA and pinB's values
  if(reading == B00001100 && aFlag) { //check that we have both pins at detent (HIGH) and that we are expecting detent on this pin's rising edge
    encoderPos --; //decrement the encoder's position count
    bFlag = 0; //reset flags for the next turn
    aFlag = 0; //reset flags for the next turn
  else if (reading == B00000100) bFlag = 1; //signal that we're expecting pinB to signal the transition to detent from free rotation
  sei(); //restart interrupts
void PinB(){
  reading = PIND & 0xC; //read all eight pin values then strip away all but pinA and pinB's values
  if (reading == B00001100 && bFlag) { //check that we have both pins at detent (HIGH) and that we are expecting detent on this pin's rising edge
    encoderPos ++; //increment the encoder's position count
  else if (reading == B00001000) aFlag = 1; //signal that we're expecting pinA to signal the transition to detent from free rotation
int Stopper=0;
int timerSet=0;
int pushedBefore=0;
      pinMode(pinA, INPUT_PULLUP); // set pinA as an input, pulled HIGH to the logic voltage (5V or 3.3V for most cases)
  pinMode(pinB, INPUT_PULLUP); // set pinB as an input, pulled HIGH to the logic voltage (5V or 3.3V for most cases)
  attachInterrupt(0,PinA,RISING); // set an interrupt on PinA, looking for a rising edge signal and executing the "PinA" Interrupt Service Routine (below)
  attachInterrupt(1,PinB, RISING); // set an interrupt on PinB, looking for a rising edge signal and executing the "PinB" Interrupt Service Routine (below)
pinMode(buttonPIN,INPUT_PULLUP);
  StartTimer();
if(started==1)
 CountDownTimer(); // run the timer
 if(pushedBefore==0){
           timerSet=1;
  if(timerSet==1)
    pushedBefore=1;
    SetTimer(0,0,encoderPos); // 10 seconds;
    timerSet=0;
  if(Stop==true)
    StopTimer();
    Serial.println("Stopped");
         started=0;
    pushedBefore=0;
    buttonState = digitalRead(buttonPIN);
 if(buttonState==0){
     started=1;
 if(oldEncPos != encoderPos) {
     uint32_t t = encoderPos;
//    s = t % 60;
//    t = (t - s)/60;
//    m = t % 60;
//    t = (t - m)/60;
//    h = t;
//   Serial.print(m);
//   Serial.print(":");
//    Serial.println(s);
  // this prevents the time from being constantly shown.
  if ((TimeHasChanged() ) &&(Stop==false))
    Serial.print(ShowMinutes());
    Serial.print(":");
    Serial.println(ShowSeconds());
boolean CountDownTimer()
  static unsigned long duration = 1000000; // 1 second
  timeFlag = false;
  if (!Stop && !Paused) // if not Stopped or Paused, run timer
    // check the time difference and see if 1 second has elapsed
    if ((_micro = micros()) - time > duration )
      Clock--;
      timeFlag = true;
      if (Clock == 0) // check to see if the clock is 0
        Stop = true; // If so, stop the timer
     // check to see if micros() has rolled over, if not,
     // then increment "time" by duration
      _micro < time ? time = _micro : time += duration;
  return !Stop; // return the state of the timer
void ResetTimer()
  SetTimer(R_clock);
  Stop = false;
void StartTimer()
  Watch = micros(); // get the initial microseconds at the start of the timer
  time = micros(); // hwd added so timer will reset if stopped and then started
  Stop = false;
  Paused = false;
void StopTimer()
  Stop = true;
void StopTimerAt(unsigned int hours, unsigned int minutes, unsigned int seconds)
  if (TimeCheck(hours, minutes, seconds) )
    Stop = true;
void PauseTimer()
  Paused = true;
void ResumeTimer() // You can resume the timer if you ever stop it.
  Paused = false;
void SetTimer(unsigned int hours, unsigned int minutes, unsigned int seconds)
  // This handles invalid time overflow ie 1(H), 0(M), 120(S) -> 1, 2, 0
  unsigned int _S = (seconds / 60), _M = (minutes / 60);
  if(_S) minutes += _S;
  if(_M) hours += _M;
  Clock = (hours * 3600) + (minutes * 60) + (seconds % 60);
  R_clock = Clock;
  Stop = false;
void SetTimer(unsigned int seconds)
 // StartTimer(seconds / 3600, (seconds / 3600) / 60, seconds % 60);
 Clock = seconds;
 R_clock = Clock;
 Stop = false;
int ShowHours()
  return Clock / 3600;
int ShowMinutes()
  return (Clock / 60) % 60;
int ShowSeconds()
  return Clock % 60;
unsigned long ShowMilliSeconds()
  return (_micro - Watch)/ 1000.0;
unsigned long ShowMicroSeconds()
  return _micro - Watch;
boolean TimeHasChanged()
  return timeFlag;
// output true if timer equals requested time
boolean TimeCheck(unsigned int hours, unsigned int minutes, unsigned int seconds)
  return (hours == ShowHours() && minutes == ShowMinutes() && seconds == ShowSeconds());
I don't think you are adjusting the time values to the present time while you are stopped.
Try the update on the button press like this
  if (buttonState == 0) {
    started = 1;
    _micro = micros();
    time = micros();
Excellent!! Thank you cattledog works a charm :) :)
