Countdown timer on LCD to control servo
hey guys, i’m currently programming an auto feeder that will feed twice a day (interval of 6 hours)
the LCD is suppose to display the countdown to 2nd feeding time, but when i try to compile it a few error has occur. i’m a beginner so please help :’(
here’s my code
#include <Servo.h> // servo library
#include <LiquidCrystal.h> // LCD library
#define irLEDpin 8
#define irSensorPin 7
#define GO 1 //switch to trigger servo motor
LiquidCrystal lcd(12,11,5,4,3,2);
Servo servoFood;
Servo servoBait;
int LDRPin = 0;
int LDRvalue = 0;
int light_sensitivity = 500;
int ledPin = 7;
const int switchPin = 4;
int switchPinState = 0;
const int feedfreqperday = 2; //the fish eats twice a day
const int numberofdays = 5; //for 5 days
const int firstfeedhour = 1;
int currenthour = 0;
int firstminutevalue = 0;
int servoposition = 0;
int feeddone = 0;
int runninghour = 0;
void setup ()
  pinMode(ledPin, OUTPUT);
  pinMode(switchPin, INPUT);
  servoFood.attach(9);
  servoBait.attach(10);
  lcd.begin(16,2);
  lcd.setCursor(0,0);
  lcd.print("Freq:2 Days:5"); // Print the stated
  lcd.setCursor(0,1);
lcd.print("1st feed hour:"); // Print the stated
lcd.setCursor (0, 2); // Choose column 0, row 2
void loop ()
int x=analogRead(A0);
if(x<500)
digitalWrite(7,HIGH);
}else
digitalWrite(7,LOW);
 servoFood.writeMicroseconds(1300); //servo rotates clockwise to dispense food
  delay(3000); //delay for 3sec
  servoBait.writeMicroseconds(1300); // survo turns to let bait go into water
  delay(120000);
  servoFood.writeMicroseconds(1700);
  servoBait.writeMicroseconds(1700);
for (feedfreqperday == 2); // freq input is 2
lcd.setCursor(9,2);
lcd.print(feedfreqperday); // total number of feed
for (runninghour = currenthour; runninghour <= 24; runninghour++) // runninghour acts as hour clock value
if (feeddone == feedfreqperday) // total number of feeds completed
setCounter = 0; // stop running the program
else if (feeddone < feedfreqperday) // feeds not completed
if (runninghour == 24) //if runninghour = 24, reset to 0 (just like hour clock)
lcd.setCursor(13,2);
lcd.print(" ");
runninghour = 0;
lcd.print(runninghour);
if (runninghour == firstfeedhour) // when runninghour value reaches the firstfeedhour
feeddone++; // feeddone will increase by 1 whenever servo rotates
lcd.setCursor(17,2);
lcd.print(feeddone);
secondfeedhour = firstfeedhour + 6; // 2nd feed hour calculated
if (secondfeedhour < 24)
newsecondfeedhour = secondfeedhour;
else if (secondfeedhour >= 24)
newsecondfeedhour = secondfeedhour - 24;
if (runninghour == newsecondfeedhour) // when runninghour reaches 2nd feed hour, servo rotates
feeddone++; // feeddone value increases
lcd.setCursor (17,2);
delay (21600000); // delay
thanks in advance!
Hello,
Indent your code,
Then, line 62 you have
I suppose it should be
if (feedfreqperday == 2)
The rest is errors about undefined variables.
    #define irLEDpin 8
    Servo servoFood;
    Servo servoBait;
    int LDRPin = 0;
    int LDRvalue = 0;
    int ledPin = 7;
    int feeddone = 0;
    int setCounter = 0;
    int secondfeedhour = 0;
    int newsecondfeedhours = 0;
    void setup ()
      lcd.begin(16,2);
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
    void loop ()
    if(x<500)
    }else
      delay(120000);
    if (feedfreqperday == 2); // freq input is 2
    lcd.setCursor(9,2);
    lcd.print(" ");
    runninghour = 0;
[code/]
i've declared the newsecondfeedhour, but the error said it is not declared. how can i fix this? :/
No, you didn't declare it, there is a difference between newsecondfeedhour and newsecondfeedhours...
And this line is still wrong:
Why do you put a semicolon at the end?
ahha! my bad my bad. totally didn't realize that. thank u so much, its working fine now :D
