I am a novice when it comes to Arduino and have done simple projects like transmitting I/O through xBee, turn simple I/O on and off, count, etc. I am looking at completing a kind of silly project that has a timer that has the ability to speed up when triggered by a simple input (possibly 8 inputs in no particular sequence). It is for one of my kids classes where they are asked a series of questions and for each wrong answer they are to push one button out of eight (no particular order). Once each button is pushed the clock begins to count down faster until time runs out.
Below is the code I have written. It does compile and download. It displays on a Adafruit LCD screen and does countdown. However, the time is off since I used a "delay." I am super rusty at this and I believe to achieve an accurate time the internal clock needs to be used or possibly the millis() statement? Any thoughts on achieving a more accurate time and how to figure on increasing the speed when an input is pressed? Thanks in advance.
#include <avr/wdt.h>
#include <Wire.h>
#include <Adafruit_RGBLCDShield.h>
#include <utility/Adafruit_MCP23017.h>
#define WHITE 0x7
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
unsigned long time;
long currentmillis = 0;
long hours = 0; //variables for hours
long mins = 0; //variables for mins
long secs = 0; //variables for secs
long timerH = 1; //time to be displayed on the LCD
long timerM = 1; //time to be displayed on the LCD
long timerS = 10; //time to be displayed on the LCD
const int LED = 13;
void softwareReset(uint8_t prescaller) //START WATCHDOG WITH THE PROVIDED PRESCALLER
wdt_enable(prescaller); //WAIT FOR THE PRESCALLER TIME TO EXPIRE
while(1){} //WITHOUT SENDING THE RESET SIGNAL BY USING THE WDT_RESET() METHOD
lcd.begin(16,2);
lcd.print("Count Downtimer");
delay(5000);
lcd.clear();
delay(150);
lcd.print("Hr ");
lcd.print("Min ");
lcd.print("Sec ");
pinMode(LED,OUTPUT);
unsigned long currentmillis = millis();
secs = currentmillis/1000;
mins = secs/60;
hours = mins/60;
while (timerH >0 || timerM >0 || timerS >=0){
lcd.setCursor(0,1);
(timerH<10)?lcd.print("0"):NULL;
lcd.print(timerH);
lcd.print(":");
lcd.setCursor(5,1);
(timerM<10)?lcd.print("0"):NULL;
lcd.print(timerM);
lcd.print(":");
lcd.setCursor(11,1);
(timerS<10)?lcd.print("0"):NULL;
lcd.print(timerS);
lcd.display();
stepDown();
void stepDown()
if ((timerS - secs) > 0)
timerS -= 1;
if (timerM - mins > 0)
timerS = 59;
timerM -= 1;
if (timerH - hours > 0)
timerS = 59;
timerM = 59;
timerH -= 1;
trigger();
void trigger() {
lcd.clear(); // clears the screen and buffer
lcd.setCursor(5, 1); // set timer position on lcd for end.
lcd.println("End Game! "); //PRINTS "END GAME" ON THE LCD
digitalWrite(LED,HIGH); //PIN 13 TURNS AN LED ON
delay(3000); //HOLD LED ON FOR 3 SEC
digitalWrite(LED,LOW); //PIN 13 TURNS LED OFF
lcd.clear(); //CLEAR THE LCD
delay(2000);
softwareReset(WDTO_1S); //RESTART IN 1 SECOND WITH TIME INSERTED IN THE BEGINNING
