Counter back to zero upon closing serial monitor
Hi All,
I have this behaviour in my code which I can not explain.
Please have a look and let me know if this is normal.
int sensePin = 2;
volatile unsigned int counter = 0;
void detect() // just a varialble to keep track of the number of hits
  counter = counter + 1;
  pinMode(sensePin, INPUT);
  attachInterrupt(0,detect,FALLING);
  Serial.flush();
  if (Serial.available() > 0)
  Serial.println(counter);
  Serial.flush();
I have a switch connected via a pull-up resistor to pin 2.
When I push the switch, the interrupt called 'detect' is triggered and counter is increased with 1.
That seems to work. To check this, I open Serial Monitor which sends me the value of counter every time I enter a character.
At first the value = 0, but that changes every time I push the button.
So far so good.
When I close the serial monitor and reopen it, then counter seems to be reset to 0 !! Why?
Does closing Arduino serial monitor reset the board ??
Any suggestions? Can it be avoided?
Disable the Arduino's autoreset feature.
http://www.arduino.cc/playground/Main/DisablingAutoResetOnSerialConnection
Many, many thanks.
