I'm trying to make a Servo sweep at a desired speed using a potentiometer. So far, I've achieved that much.
But I want to make that same servo (and therefore the sweeping) turn on and off whenever a sensor (IR infrared obstacle avoidance sensor) detects something close (very similar to a push button counter?)
However, in the code I'm currently using, something weird is happening:
By the second (2) push, the servo starts sweeping with the speed designated by the potentiometer.
But the sensor/serial monitor wont mark the third (3) push. I don't get why. Sometimes after many tries the third push will be perceived randomly, but I still haven't figured out why.
Then the fourth (4) and fifth (5) pushes are easily perceived by the sensor and noted on the serial monitor, but nothing happens.
It is only on the sixth (6) push that the servo starts sweeping again. And then the sensor/serial monitor won't work properly again (like in the second push). And just like in pushes 4 and 5, pushes 8 and 9 are perciebed but do nothing.
Here's the code:
#include <Servo.h>
Servo ServoFeliz;
int pos = 0;
int sensor_pin = 7; //IR sensor pin
int sensorCounter = 0; // counter for the number of sensor changes
int sensorState = 0; // current state of the sensor
int lastSensorState = 0; // previous state of the sensor
int potpin = A0; =/potentiometer pin
int PotpinVal; //potentiometer val
pinMode (sensor_pin, INPUT);
ServoFeliz.attach(9);
PotpinVal = analogRead(potpin);
PotpinVal = map(PotpinVal, 1, 1023, 1, 25); // lectura del valor del potenciometro (entre 1 y 1023
sensorState = digitalRead(sensor_pin);
// compare the sensorState to its previous state
if (sensorState != lastSensorState) {
// if the state has changed, increment the counter
if (sensorState == HIGH) {
// if the current state is HIGH then the sensor went from off to on:
sensorCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(sensorCounter);
// if the current state is LOW then the sensor went from on to off:
Serial.println("off");
// Delay a little to avoid bouncing
delay(15);
// save current state as last state, for next time through the loop
lastSensorState = sensorState;
if (sensorCounter % 4 == 1) {
ServoFeliz.write(0);
delay(15);
} else if (sensorCounter % 4 == 2) {
for (pos = 0; pos <= 180; pos += 1) {
// in steps of 1 degree
ServoFeliz.write(pos);
delay(PotpinVal);
for (pos = 180; pos >= 0; pos -= 1) {
delay(PotpinVal);
} else if (sensorCounter % 4 == 3) {
delay(15);
All I really want is for the IR sensor to work as an on off switch
(Sensor HIGH&LOW= on, and next HIGH&LOW = off.).
I don't want the servo to only work when the sensor is on HIGH and stop working when the sensor is LOW. That would defeat the purpose of the mechanism.
I would really appreciate any help.
