Counter implementation on IR sensor
Hello, I am currently working on a code for my versity project where two individual outputs fire at a time depending on different number of rotations. I am counting revolutions by IR sensor.I am facing troubles doing it. I am still getting outputs even if there's no input given on the IR. My code is below, can someone tell me what is wrong in it. TIA
(PS: I am kinda new in this so pardon me for any mistake )
int x = 0;
int cycle = 0;
int state = 0;
  pinMode(A0, INPUT);
  pinMode(A2, INPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  int x = digitalRead(A0);
  if (state == 0) {
    switch (x) {
      case 1: state = 1; cycle = cycle + 1; break; //measuring the revolution
      case 0: state = 0; break;
  if (x == LOW) {
    state = 0;
  Serial.println(cycle);
  if (cycle > 0) {
    if (cycle % 2 != 0) { //odd numbers of revolution will give output in pin 9
      if (digitalRead(A0) == 1) {
        digitalWrite(9, HIGH);
        digitalWrite(10, LOW);
      else if (digitalRead(A0) == 0) { //no input so no output
        digitalWrite(9, LOW);
    if (cycle % 2 == 0) {
      if (digitalRead(A2) == 1) { //even numbers of rotation will fire pin 10
        digitalWrite(10, HIGH);
      else if (digitalRead(A2) == 0) {
Hello, I added code tags for you for this time but do yourself a favour and please read How to get the best out of this forum
we are missing a diagram describing how things (what things) are wired together.
your code is complicated to read because variables do not convey any meaning. what does it mean if x is HIGH or LOW ? (and what is x anyway). What does state 0 represent (you could use enum to get more meaningful names instead of 0 and 1 - or just use a bool if you have 2 states)
what's the use for
if you enter the if that leads to that switch/case, you know state is 0 already...
what is a revolution?
Depending on the sensor, you may need a pullup/pulldown resistor or some debouncing.
@saminyasar8936
1. Example of Input Line with Internal (built-in) Pull-up Resistor (Fig-1).
InputlineInternalPullup
Figure-1:
Code:
pinMode(A0, INPUT_PULLUP);
2. Example Input Line without Internal Pull-up Resistor but with externally installed pull-up Resistor (Fig-2).
InputLine ExternalPullup
Figure-2:
Code:
pinMode(A0, INPUT);
3. Example of Input Line with Externally installed Pull-down Resistor (Fig-3).
InputlineExternalPullDown
Figure-3:
Code:
pinMode(A0, INPUT);
