im writing a sketch to monitor an appliance in my house. i want to count how often it turns on during the day and how long it runs for. im slowly trying to figure out the programming side of things. my current issue is that i have a counter that increments by 1 every time a button is pushed. i aslo tried to program a reset feature for the counter, but it doesn't seem to work? when i push the reset button it prints 0 (for debugging) but then the counter continues where it left off never reseting back to zero?
const int switchPin = 2; // number of input pin
const int resetPin = 3; // increment reset
long startTime; //value returned from millis when switch is pressed
long duration; //variable to store duration
long seconds; // variable to store seconds
long minutes; // variable to store minutes
long counter; // variable to store number of times switch is pressed
pinMode(switchPin, INPUT);
digitalWrite(switchPin, HIGH); //turn on pull up resistor
pinMode(resetPin, INPUT);
digitalWrite(resetPin, HIGH); //turn on pull up resistor
long counter = 0;
if(digitalRead(resetPin)==LOW)
long counter = 0;
Serial.println(counter);
if(digitalRead(switchPin) == LOW)
startTime = millis();
while(digitalRead(switchPin) == LOW);
long duration = millis() - startTime;
long seconds = (duration / 1000) % 60; // convert milliseconds to seconds
Serial.print("s ");
Serial.println(seconds);
long minutes = (duration / 60000) % 60; //convert milliseconds to minutes
Serial.print("m ");
Serial.println(minutes);
counter++;
/code]
