Counter/timer 0 - CTC mode
Hi every one,
This time, I am trying to use the timer/counter 0 in CTC mode using the following code :
// Set PD6 as output
DDRD |= (1<<PD6);
//Set Initial Timer value
TCNT0=0;
//Place TOP timer value to Output compare register A
OCR0A=111;
// Set CTC mode (Clear Timer on Compare Match) → mode 2 (010)
// and make toggle PD6/OC0A pin on compare match (debugging purpose)
TCCR0A &=~(1<<COM0A1);
TCCR0A |=(1<<COM0A0)|(1<<WGM01);
TCCR0A &=~(1<<WGM00);
TCCR0B &=~(1<<WGM02);
// Set prescaler 8 and start timer (010)
// Frequency = 16 000 000 / 8 / 112 approx.: 17 857 hz)
TCCR0B &=~(1<<CS02);
TCCR0B |=(1<<CS01);
TCCR0B &=~(1<<CS00);
The oscilloscope shows a signal on pin PD6 with a very low frequency (approx.: 50 hz) :frowning:
I want to produce a timer frequency of 17 857 hz.
What is wrong or missing with ma code ?
Thank you for your help.
I’m not sure what is wrong with the posted code, but if you initialized the TCCR0A and TCCR0B registers to 0 and then just set the bits you want and don’t try all the clearing of bits with &=~ you get what you want. I’ve looked at the final register settings with both approaches and can’t see any difference so I don’t know the root cause.
    DDRD |= (1<<PD6);
    TCCR0A = 0;
    TCCR0B = 0;
    TCNT0=0;
    OCR0A=111;
    // Set CTC mode (Clear Timer on Compare Match) --> mode 2 (010)
   // TCCR0A &=~(1<<COM0A1);
    //TCCR0A &=~(1<<WGM00);
    //TCCR0B &=~(1<<WGM02);
   // TCCR0B &=~(1<<CS02);
    TCCR0B |=(1<<CS01);
   // TCCR0B &=~(1<<CS00);
Your code works perfectly ! :)
I wouldn't have found the solution to that problem by myself.
Once again, thank you for your help !
It is very appreciated !
