Your codes work well; however, I would be glad should your codes stand at more literate side having comments, treating Port-B as a 6-bit input port as there are only 6 active bits and if() structure, preferably, be followed by {}.
DDRB = 0x00; //inputs: PB5 - PB0 = 010101
byte x = PINB;
byte B_cnt = 0;
for (uint8_t i = 0; i<6; i++)//i < 8; ++i)
if (x & 0x01) //checking PINB0, PIB1, ..., PINB5; x remains undisturbed
++B_cnt; //LH found; increase counter
x >>= 1; //x is shifted right by 1-bit and then assigned back to x
Serial.println(B_cnt);
Alternative Sketch with 7 lines of Codes
byte B_cnt = 0;
for (int i = 0; i < 6; i++)
if (bitRead(PINB, i) == HIGH)
++B_cnt;
Serial.println(B_cnt); //shows: 3
An array with 256 entries, each with the number of corresponding 1s would be efficient in terms of speed but not memory, unless that does not matter.
efficient either in terms of speed and memory usage. its any open question on how to count the 1’s!
another way of count the 1’s in the byte would be this:
for(uint8_t i=1; i>0;i<<=1){
if(x&i) ++B_cnt;
so… of these 2 (of course other options are welcomed!) which one is more efficient from a compiler perpective (speed or memory). is there an even better way of count the 1’s?
Given the lack of a barrel shifter some variation of your code (e.g. @Whandall's) is very likely the most overall efficient.
If the compiler has a specific optimization then shifting left and comparing to less-than-zero may reduce to the smallest possible code (which will also very likely be the fastest).
Comparison of execution times of various Programs Presented so far:
OP’s Option-1 (OP) 4 cycles ----------> 4* 1/16106 = 0.25 us
Post#2 9 cycles ----------> 9 1/16106 = 0.5625 uS
Post#4 (Option-2) 4 cycles ----------> 4 1/16106 = 0.25 us
Post#6 32 cycles ------------> 32 1/16*106 = 2.00 us
To measure execution time of a sketch, the TC1 is made ON at 16 MHz clock just at the beginning of execution. The TC1 is made OFF just after finishing the execution of the program. The content of TCNT1 is directly proportional to program execution time. The codes are given below:
//Timer-1 as a n Internal Pulse Counter----
TCCR1A = 0x00; //Normal UpCounting Mode
TCCR1B = 0x00; //TC1 is OFF is OFF
TCNT1 = 0x00; //Initial Value
TCCR1B = 0x01; //TC1 is ON with 16 MHz clkTC1
//32 cycles Post#5
byte x = PINB;
byte B_cnt = 0;
for (; x; x >>= 1)
if (x & 1)
B_cnt++;
Serial.println(TCNT1, DEC); //execution time as cycles
/* 4 cycles Post#4
byte x = PINB;
byte B_cnt = 0;
for (uint8_t i = 1; i > 0; i <<= 1)
if (x & i) ++B_cnt;
/* 9 cycles Post#2
byte x = PINB;
byte B_cnt = 0;
++B_cnt;
/* 4 cycles OP's Option-1
byte x = PINB;
byte B_cnt = 0;
for (uint8_t i = 0; i < 8; ++i)
if (x & 0x01) ++B_cnt;
x >>= 1;
GolamMostafa:
Execution time of your codes is: 27 cycles = 27 1/16106 = 1.6875 us
So far, we have executed time as low as 0.25 us (Post#9).
You seem to be looking at clocks per iteration, while ignoring the number of iterations. My code will iterate a different number of times, from 0 to 8, depending on the input data, so it does NOT have a single execution time. All the other solutions I saw, except table lookup, will iterate 8 times, even if NONE of those change the output at all.
Regards,
Ray L.
RayLivingston:
Thank you very for reminding the very important issue. I have now connected LH at all the input pins of Port-B and then computed the execution time. It is now 1862 cycles (116.375 us). Previous execution time was for the input values of 101000 (B_cnt = 2).
TCCR1B = 0x00; //T1 is OFF
TCCR1B = 0x01; //16 MHz
//1862 cycles Post#15
DDRB = 0x00; //inputs: PB5 - PB0 = 111111
byte x = PINB;
Serial.println(x, HEX);//111111 = 3F
byte B_cnt = 0;
while (x)
B_cnt += x & 0x01;
x >>= 1;
TCCR1B = 0x00;
Serial.println(B_cnt); //6
