Hi all,
I'm New to the community so apologies for the lack of knowledge. I'm thinking of a project where I want to measure depth of an needle/bar/catheter as it passes a certain point. The needles in question already has lines indicating Depth (1 line = 1 cm). Ie. I need some sort of optical sensor that’s able to detect the lines as the pass the optical sensor and count them as 1, it would also be helpful that the software can detect lines going in the opposite direction, ie. The needle is being taken out for whatever reason, however this is not critical at this point. I was hoping for an optical sensor.
See attached pictures for reference to the proposed needles even though I will be using needles/catheres that have solid single lines.
Thank you in advance for any suggestions!
Regards,
Håvard Jenssen
