#include <MIDI_controller.h>
#include <MIDIUSB.h>
#include <LiquidCrystal.h>
#define VELOCITY 0b01111111
#define LATCHTIME 100
#define SPEED_MULTIPLY 1
#define PULSES_PER_STEP 4
#define ANALOG_AVERAGE 8
const int buttonPin1 = A1;
const int BUTTON1 = 1;
const int BUTTON2 = 2;
const int BUTTON3 = 3;
const int BUTTON4 = 4;
const int BUTTON5 = 5;
const int BUTTON6 = 6;
const int BUTTON1LOW = 970;
const int BUTTON1HIGH = 1024;
const int BUTTON2LOW = 750;
const int BUTTON2HIGH = 800;
const int BUTTON3LOW = 600;
const int BUTTON3HIGH = 660;
const int BUTTON4LOW = 400;
const int BUTTON4HIGH = 450;
const int BUTTON5LOW = 270;
const int BUTTON5HIGH = 320;
const int BUTTON6LOW = 50;
const int BUTTON6HIGH = 100;
// Variables will change:
int buttonState1; // the current reading from the input pin
int lastButtonState1 = LOW; // the previous reading from the input pin
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime1 = 0; // the last time the output pin was toggled
long debounceDelay1 = 50; // the debounce time; increase if the output flickers
// initialize the library with the numbers of the interface pins for LCD
LiquidCrystal lcd(22, 24, 23, 25, 27, 29);
void noteOn(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
//_____________________________________________________________________________________________________________________________________________________________________________________________
//Serial.begin(9600);
pinMode(buttonPin1, INPUT);
// set up the LCD's number of columns and rows:
lcd.begin(20, 2);
// Print a message to the LCD.
lcd.setCursor(0, 0); //position cursor
lcd.print(" Cont Pivot Sat ");
lcd.setCursor(0, 1); //position cursor
lcd.print(" Hue Lum Mix ");
USBMidiController.setDelay(15); // wait 15 ms after each message not to flood the connection
delay(1000); // Wait a second...
void controlChange(byte channel, byte control, byte value) {
midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
MidiUSB.sendMIDI(event);
void loop() // Refresh all inputs
// read the state of the switch into a local variable:
int reading1 = analogRead(buttonPin1);
//Serial.println(reading1);
int tmpButtonState1 = LOW; // the current reading from the input pin
if (reading1 > BUTTON6LOW && reading1 < BUTTON6HIGH) {
//Read switch 6
tmpButtonState1 = BUTTON6;
} else if (reading1 > BUTTON5LOW && reading1 < BUTTON5HIGH) {
//Read switch 5
tmpButtonState1 = BUTTON5;
} else if (reading1 > BUTTON4LOW && reading1 < BUTTON4HIGH) {
//Read switch 4
tmpButtonState1 = BUTTON4;
} else if (reading1 > BUTTON3LOW && reading1 < BUTTON3HIGH) {
//Read switch 3
tmpButtonState1 = BUTTON3;
} else if (reading1 > BUTTON2LOW && reading1 < BUTTON2HIGH) {
//Read switch 2
tmpButtonState1 = BUTTON2;
} else if (reading1 > BUTTON1LOW && reading1 < BUTTON1HIGH) {
//Read switch 1
tmpButtonState1 = BUTTON1;
//No button is pressed;
// check to see if you just pressed the button
// (i.e. the input went from LOW to a buttonState), and you've waited
// long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (tmpButtonState1 != lastButtonState1) {
// reset the debouncing timer
lastDebounceTime1 = millis();
if ((millis() - lastDebounceTime1) > debounceDelay1) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
buttonState1 = tmpButtonState1;
// Serial.println(buttonState);
// save the reading. Next time through the loop,
// it'll be the lastButtonState:
lastButtonState1 = tmpButtonState1;
// set the LED using the state of the button for testing:
switch (buttonState1) {
case BUTTON1:
noteOn(0, 53, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 52, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 48, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 49, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 50, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 86, 64); // B-S-M Submenu off
MidiUSB.flush();
delay(50);
noteOff(0, 87, 64); // Curves Submenu Off
MidiUSB.flush();
case BUTTON2:
lcd.print("Temp Tint MD");
lcd.print("Col Bst Shad HL");
noteOn(0, 48, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 53, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 52, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 49, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 50, 64);
MidiUSB.flush();
delay(50);
MidiUSB.flush();
delay(50);
MidiUSB.flush();
case BUTTON3:
lcd.print("Low High ");
lcd.print("L.S. H.S. ");
noteOn(0, 87, 64); // Curves Submenu On
MidiUSB.flush();
delay(20);
MidiUSB.flush();
delay(20);
noteOff(0, 53, 64);
MidiUSB.flush();
delay(20);
noteOff(0, 48, 64);
MidiUSB.flush();
delay(20);
noteOff(0, 52, 64);
MidiUSB.flush();
delay(20);
noteOff(0, 50, 64);
MidiUSB.flush();
delay(20);
MidiUSB.flush();
case BUTTON4:
lcd.print("Size Pan Rotate");
lcd.print("Aspect Tilt Opacity");
noteOn(0, 50, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 53, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 48, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 52, 64);
MidiUSB.flush();
delay(50);
MidiUSB.flush();
delay(50);
MidiUSB.flush();
case BUTTON5:
lcd.print("Radius H/V Rat Scal");
lcd.print("Cor S Level Mix ");
noteOn(0, 86, 64); // B-S-M Submenu on
MidiUSB.flush();
delay(20);
noteOff(0, 53, 64);
MidiUSB.flush();
delay(20);
MidiUSB.flush();
delay(20);
noteOff(0, 48, 64);
MidiUSB.flush();
delay(20);
noteOff(0, 50, 64);
MidiUSB.flush();
delay(20);
noteOff(0, 52, 64);
MidiUSB.flush();
delay(20);
MidiUSB.flush();
case BUTTON6:
lcd.print(" Pan Tilt Zoom");
lcd.print("Rotate Width Height");
noteOn(0, 52, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 53, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 48, 64);
MidiUSB.flush();
delay(50);
noteOff(0, 50, 64);
MidiUSB.flush();
delay(50);
MidiUSB.flush();
delay(50);
MidiUSB.flush();
