Counting Button Presses
I know that this is probably very easy code.. but I want to be able to print how many times a button has best pressed within 5 seconds. For example, if i press a button 7 times within a 5 seconds time frame, it will print, "the button has been pressed 7 times....
Within any given 5 seconds? Or does the 5 second window start when the button is first pressed?
In other words, once the button is pressed, do nothing else for 5 seconds except count button presses?
The first time the button is pressed is when the five seconds starts, and then when the five seconds is over, it will stop. then repeat...
long firstPress = 0;
long countingTime = 5000;
int presses  = 0;
int buttonPin = 3; // Or whatever...
   if(digitalRead(buttonPin) == HIGH)
       firstPress = millis();
       presses = 1;
       while(millis() - firstPress < countingTime)
               presses++;
   // Do something about the button presses...
Some delay after each digitalRead returned HIGH will most likely be needed, to prevent button bounce inaccuracies from affecting the count, but this is the general idea. Keep the delay small - 5 milliseconds, or so.
