Counting does not happen correctly
Hello,
I want my waterpump to turn on max 5 times but when I set the counter to a maximum value of 5 the maximum times the waterpump will be on is 6.
When I put it to 4 it will be correct (5).
Why is this?
      if(Sproei_Teller <= 4)// Als ik deze op 5 zet dan wordt het maximum sproei keren 6
        if(meting_vsensor >= Sproei_Laagste_Waarde)
         if(digitalRead(relais_water) == LOW)
          Serial.println("Sproei Teller + 1");
          Serial.println("Waterpomp: AAN");
          Sproei_Teller++;
          digitalWrite(relais_water, HIGH);
There are five values in the range 0-4. All of them are less than or equal to four, hence the if() condition is met.
dougp:
oooh okay, I get it now thanks! :smiley:
