Counting down instead of up
Hey I got this code when button is pushed it the led bar will light up till max 8 leds on and a corresponding strength will go as motor speed, I'm tryin to figure how to set it the other way around meaning that lets say you pushed it and got 4 leds, now you push diff button and can lower it, it seems I cant figure what to change here, Ta
That code is not complete.
Start by identifying how the code that you didn't post detects a button press. You need to detect the press of a second button
In the small portion of code that you did post what is it that increments the number of pixels to be displayed ?
When you call the power() function the current code always increments the number of pixels to be displayed. You will need to determine which button has been pressed and either increment or decrement that number before displaying the LEDs and don't forget that when you need to display fewer LEDs that some of the higher ones need to be turned off first
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
