Counting down time to target while AccelStepper is running
Hi, I'm building a motorized camera slider with a stepper motor that is controlled by AccelStepper. I want to display a countdown time to target on a oled display how should I go about coding that?
At the moment I have everything working I can set the duration that the slider will take to run from end to end and display that on the OLED display, but when I press start and the AccelStepper started running (stepperX.runToNewPosition(15000); ) I have to wait until it finishes the run before I can make any change to the OLED display, so if there is any way I can make changes to the display while AccelStepper is running (stepperX.runToNewPosition(15000); )?
  //Slider Setup display 2
    Serial.println("Set the Duration");
    display.clearDisplay();
    display.setTextSize(2);
    display.setTextColor(WHITE);
    display.setCursor(0, 0);
    display.println("Set the   Duration");
    display.display();
  while (digitalRead(button1))    //    set duration in second
    inputA = analogRead(A0);    //  Read Potentiomenter
    if ((inputA > previous + 4) || (inputA < previous - 4)) //  Signal filter
      durationSec = map(inputA, 0, 1023, 0, 59); //    set duration in second write to "durationSec"
      previous = inputA;
        Serial.println(inputA);   //    display duration of travel on display (set Seconds)
        display.setCursor(5, 0);
        display.println("0");
        display.setCursor(68, 0);
        display.println(durationSec);
        display.setTextSize(1);
        display.setCursor(5, 7);
        display.println("      Min       Sec");
        display.setCursor(5, 23);
        display.println("Set Seconds");    //    press set to confirm duration
        display.display();
  while (digitalRead(button1))    //    set duration in minutes
      durationMin = map(inputA, 0, 1023, 0, 120); //    set duration in Minute write to "durationMin"
      previous = inputA;
        Serial.println(inputA);   //    display duration of travel on display (set Minutes)
        display.println(durationMin);
        display.println("Set to confirm");    //    press set to confirm duration
        display.display();
    Speed = (15000 / ((durationMin * 60) + durationSec));
    digitalWrite(enPin, LOW);   //  Enable mortor
    stepperX.setAcceleration(6000);  //  Set Acceleration
  while (digitalRead(button1))    //    press start to start the run
    Serial.println("Press to start");
    display.setCursor(0, 14);
    display.println("Press Start to Begin");
    display.display();
    delay(250);
    if (!digitalRead(button2))
      delay(250);
      while (digitalRead(button2))
            Serial.println("Running");    //    display status and duration setting
            { //  display setting
              display.println("Running");
              display.setCursor(5, 18);
              display.setCursor(68, 18);
              display.display();
          stepperX.setMaxSpeed(Speed);
          stepperX.runToNewPosition(15000);    //    Move stepper to end
              display.display();
          stepperX.runToNewPosition(0);  // Move stepper to end
      Serial.println("Stopped");    //      Display status (stopped)
      display.println("Stopped!");
      display.display();
      delay(3000);
That is because runToNewPosition() is a blocking function. That function does not return until the stepper is at the new position. It IS possible, and even easy, to set the position, and then call run() repeatedly (every time through loop()), and the stepper will eventually get there, but where you will be able to do other things while the stepper is stepping.
