Hi!
I'm working on a project that is using a PIR sensor, lights a led and then counts the number of events. After reaching a number something is going to happen (though that's not in the code now).
However I'm getting some really weird numbers. Instead of increasing by one, as I expected it too, it is increasing, but in intervals that I don't really understand the pattern of. Could someone please point me in the right direction..?
int ledPin = 13; // pin for the LED
int inputPin = 8; // input pin for the PIR sensor
int pirState = LOW; // no motion detected to start with
int val = 0; // var for reading the pin status
int counter = 0; // count the events
pinMode(ledPin, OUTPUT); // LED as output
pinMode(inputPin, INPUT); // sensor as input
void loop(){
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
counter++;
delay(150);
if (pirState == LOW) {
Serial.println("Motion!"); // We only want to print on the output change, not state
pirState = HIGH;
Serial.println(counter);
digitalWrite(ledPin, LOW); // turn LED OFF
delay(300);
if (pirState == HIGH){
// we have just turned of
Serial.println("Motion ended!");
pirState = LOW;
