counting how many times a button has been pressed
Hello everybody,
For checking a the number of times a button (connected to pin 12) has been pressed I wrote this small program. The program " buttoncount.ino" is also included as attachment.
int buttonPushCounter = 0;
int buttonState = 1;
int lastButtonState = 1;
void setup(){
digitalWrite(11,HIGH);//activation of the pull-up resistor of pin 11
void loop(){
buttonState = digitalRead(11);
if (buttonState != lastButtonState) {
if (buttonState == LOW) {
buttonPushCounter++;
lastButtonState = buttonState;
Serial.println(buttonPushCounter);
It seems to work but when I integrate it in a bigger program (used as a library) the counting doesn’t detect all the presses. And often it jumps in steps of two (especially when I tap the button and don’t hold it for 0.5s).
Anyone an idea what is wrong?
Thanks in advance,
Bart
buttoncount.ino (434 Bytes)
const int buttonPin = 12;    // the number of the pushbutton pin
const int ledPin = 13;      // the number of the LED pin
// Variables will change:
int ledState = HIGH;         // the current state of the output pin
int buttonState;             // the current reading from the input pin
int lastButtonState = LOW;   // the previous reading from the input pin
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0;  // the last time the output pin was toggled
long debounceDelay = 50;    // the debounce time; increase if the output flickers
  pinMode(buttonPin, INPUT);
  pinMode(ledPin, OUTPUT);
  // set initial LED state
  digitalWrite(ledPin, ledState);
  // read the state of the switch into a local variable:
  int reading = digitalRead(buttonPin);
  // check to see if you just pressed the button
  // (i.e. the input went from LOW to HIGH),  and you've waited
  // long enough since the last press to ignore any noise:
  // If the switch changed, due to noise or pressing:
  if (reading != lastButtonState) {
    // reset the debouncing timer
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer
    // than the debounce delay, so take it as the actual current state:
    // if the button state has changed:
    if (reading != buttonState) {
      buttonState = reading;
      // only toggle the LED if the new button state is HIGH
      if (buttonState == HIGH) {
        ledState = !ledState;
  // set the LED:
  // save the reading.  Next time through the loop,
  // it'll be the lastButtonState:
  lastButtonState = reading;
check the code. it will work for you. i have not added counter variable. please include it
This:
Should be:
pinMode (11, INPUT_PULLUP); // pin 11 is set as input using internal pull-up
Try including a button debounce code here and here.
**Or use the code AMPS-N posted.
