Counting how many times each LED has turned on
I have a function that turns on a random LED out of 8 based on randomly generated number in the range of 256. I need to count how many times each LED has turned on and use this number to turn on each LED as many times as it was turned on randomly. I am using for loop to run it 100 times.
for (int i = 0; i < 100; ++i)
		randomLED();
And my function is:
void randomLED()
	int index;
	index = random(256);
	int index;
	int del3 = 100;
		if (index <= 31)
			digitalWrite(ledPins[0], HIGH);
			delay(del3);
			digitalWrite(ledPins[0], LOW);
		else if (index >= 32 && index <= 63)
			digitalWrite(ledPins[1], HIGH);
			delay(del3);
			digitalWrite(ledPins[1], LOW);
		else if (index >= 64 && index <= 95)
			digitalWrite(ledPins[2], HIGH);
			delay(del3);
			digitalWrite(ledPins[2], LOW);
		else if (index >= 96 && index <= 127)
			digitalWrite(ledPins[3], HIGH);
			delay(del3);
			digitalWrite(ledPins[3], LOW);
		else if (index >= 128 && index <= 159)
			digitalWrite(ledPins[4], HIGH);
			delay(del3);
			digitalWrite(ledPins[4], LOW);
		else if (index >= 160 && index <= 191)
			digitalWrite(ledPins[5], HIGH);
			delay(del3);
			digitalWrite(ledPins[5], LOW);
		else if (index >= 192 && index <= 223)
			digitalWrite(ledPins[6], HIGH);
			delay(del3);
			digitalWrite(ledPins[6], LOW);
		else if (index >= 224 && index <= 256)
			digitalWrite(ledPins[7], HIGH);
			delay(del3);
			digitalWrite(ledPins[7], LOW);
		delay(del3);
		randomSeed(analogRead(1));
  int index;
  int index;
How many variables called index do you want?
I had a problem with my index because I did not define it in correct function. I changed it:
	int index = random(256);
	int del3 = 100
I am just trying to understand how can I make the function return a value for each time it runs and then store it until it is not executed 100 times.
randomLED is a void function; it can’t return a value.
Maybe fix that first.
When you get around to posting again, please don't cut up your program, paste the complete sketch.
goldencaravan:
If the same LED is on twice in succession does that count as one or two turn-ons?
you have already an array for your led pins.
So add an additional array for your counters:
byte ledCounter[8];
and increase the counter when you switch on the led
ledCounter*++;*
