Hey. im creating a robot with a ultrasonic sensor and two DC motors. I have the robot programmed to drive straight until it detects a wall a certain distance away. Once it detects the wall i made the robot turn right and i have the code return to the void loop where it determines weather how far the wall away is. I wanted to use a boolean statement where it states that the wall is a certain distance away and (&&) a specific loop was ran once. Can the code count how many times a loop was ran and if so how do you code it in the program using boolean
Yes.
unsigned long loopCount = 0;
loopCount++;
// Do other stuff
Do not expect the value in loopCount to mean anything, though.
How do YOU count using true and false?
PaulS:
static boolean isOdd = false;
isOdd = !isOdd;
if(!isOdd) Serial.println("Even numbered loop!");
