I am working on a project to monitor hand hygiene compliance. I need to count the amount of compliance and noncompliance instances of an individual healthcare worker.
While I was working on the scenario on Bed A -> handwash -> Bed A -> Leave -> No handwash
The first round, the compliance count was correct at the end of the code.
I went ahead to do a second round of testing. However, the compliance count returned an extremely large value after I copied tagString to storeString in void loop(). (There was no such problem in the first round of testing)
I am not sure why there's such a large jump of about 14000 in compliance count. The count in the 3rd test is the same as the 2nd.
#include <VirtualWire.h>
const int receive_pin = 2; //pin number to change accordingly
int RFIDResetPin = 13;
int buttonState = 0;
int buttonPin = 8;
int ledPin = 11;
int handWash = 0; //Status of Handwash
int bed = 0; //Status of Current Bed
int newBed = 0; //Status of a change in Bed
int currentBed = 0; //Status of current Bed (only after handwash)
int readByte;
char tagString[13]={0}; //A string to assign tags’s serial numbers
char storeString[13] = {0}; //to store the previous tagString value of bed A/B
long lastMillis = 0; //variable to store last time LED was updated
unsigned long currentMillis;
int compliance = 0;
int noncompliance = 0;
int store = 0;
int changeCount = 0;
///////Receiver Declaration/////////
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
//Register your RFID tags here
char bedTagA1[13] = “6F005C6280D1”; //bed A tag
char bedTagA2[13] = “6F005C74783F”; //bed A tag
char bedTagB1[13] = “6F005C6DF1AF”; //bed B tag
char bedTagB2[13] = “6F005CB57EF8”; //bed B tag
char dispTag[13] = “6F005C70ACEF”; //dispenser tag
pinMode(ledPin, OUTPUT);
pinMode(buttonPin,INPUT);
///////////////////Receiver Code///////////////////////
vw_set_rx_pin(receive_pin);
vw_set_ptt_inverted(true); // Required for DR3100
vw_setup(2000); // Bits per sec
vw_rx_start(); // Start the receiver PLL running
currentMillis = millis();
buttonState = digitalRead(buttonPin);
if(strlen(tagString) == 0 && strlen(storeString) == 0) //no bed and previous bed
readTag(); //read for RFID tag
checkLED();
checkLast();
if(compareTag(tagString,dispTag) && (buttonState == HIGH)/vw_get_message(buf, &buflen)/ && handWash == 0)
Serial.println(“Bed: Handwashed (1)”);
offAlarm();
handWash = 1;
newBed = 0;
lastMillis = currentMillis;
if((compareTag(tagString, bedTagA1) || compareTag(tagString,bedTagA2))) //bed A
bed = 1; //indicates bed A
if(strlen(storeString) == 0)
for(int i = 0; i < strlen(tagString) ; i++)
storeString = tagString*; //make a copy of tagString into storeString* * }* * }* * lastMillis = currentMillis; //the time of approach* * }* * else if((compareTag(tagString, bedTagB1) || compareTag(tagString,bedTagB2))) //bed B* * {* * bed = 2; //indicates bed b* * if(strlen(storeString) == 0)* * {* * for(int i = 0; i < strlen(tagString) ; i++)* * {* storeString = tagString*; //make a copy of tagString into storeString* * }* * }* * lastMillis = currentMillis; //the time of approach* * }* * while(strlen(tagString) != 0)* * {* * if(compareTag(tagString,dispTag))* * {* * clearTag(tagString);* * break;* * }* * else* * {* * gotBed(bed);* * }* * }* * while(strlen(tagString) == 0 && strlen(storeString) != 0) //no bed but have previous bed* * {* * bed = -1;* * noBed();* * }* * resetReader(); //reset the RFID reader* } void gotBed(int bed) { * currentMillis = millis();* * checkHandwash();* * if(newBed != bed && handWash == 0) //Transitioning into bed A without handwash* * {* * Serial.println(“Bed: No handwash (1)”);* * newBed = bed; //indicates a new bed is detected* * lastMillis = currentMillis;* * onAlarm();* * }* * if(newBed == bed && handWash == 0) //when a change in bed is detected* * {* * if(currentMillis - lastMillis > 10000UL) //needs to handwash within 10 seconds* * {* * Serial.println(“Bed: No handwash (2)”);* * noncompliance++;* * lastMillis = currentMillis;* * newBed = 0;* * offAlarm();* * clearTag(tagString);* * clearTag(storeString);* * }* * }* * if(newBed != bed && handWash == 1) //Transitioning into bed A with handwash* * {* * if(currentBed != bed && currentBed == 0) //First Bed* * {* * Serial.println(“Bed: Handwashed (2)”);* * currentBed = bed; //indicates hand is washed for first Bed* * changeCount = 0;* * changeCount++; //increase number of bedstate changes* * lastMillis = currentMillis;* * clearTag(tagString);* * }* * else if(currentBed != bed && currentBed > 0 && changeCount == 1) //After dispenser, HCW can approach either bed (allows bed change)* * {* * Serial.println(“Bed: First Bed”);* * if(changeCount < 2)* * {* * compliance++;* * changeCount++; //increase change count to disallow next bed change* * Serial.println(compliance);* * }* * currentBed = bed; //handwash identified for currentBed* * lastMillis = currentMillis;* * clearTag(tagString);* * }* * else if(currentBed != bed && currentBed > 0 && changeCount == 2) //2nd change* * {* * Serial.println(“Bed: Change in Bed”);* * changeCount = 0; //resets change counter* * handWash = 0; //resets handwash* * currentBed = 0; //resets currentbed* * lastMillis = currentMillis;* * }* * else if(currentBed == bed) //same bed after handwash //////////////////////////else if/////////////////////////////////* * {* * Serial.println(“Bed: Safe to Proceed”);* * if(changeCount < 2)* * {* * compliance++;* * changeCount++;* * Serial.println(compliance);* * }* * lastMillis = currentMillis;* * clearTag(tagString);* * }* * }* } void noBed() { * currentMillis = millis();* * readTag();* * resetReader();* * if(strlen(tagString) != 0)* * {* * lastMillis = currentMillis;* * }* * else if(strlen(tagString) == 0) //disable “leave” after dispenser* * {* * if(currentMillis - lastMillis > 6000UL && changeCount != 1) //more than 6 seconds after leaving bed* * {* * if(newBed != bed && currentBed == 1) //Transitioning from bed A to no bed* * {* * Serial.println(“Bed A: Leave”);* * newBed = -1;* * handWash = 0; //resets the timer* * }* * else if(newBed != bed && currentBed == 2) //Tranistioning from bed B to no bed* * {* * Serial.println(“Bed B: Leave”);* * newBed = -1;* * handWash = 0; //resets the timer* * }* * onAlarm(); //hand wash is needed when HCW leave bed for more than 6 seconds* * changeCount = 0;* * newBed = 0;* * currentBed = 0; //indicates no bed* * lastMillis = currentMillis;* * clearTag(storeString);//clear existing memory of previous bed* * }* * else if(currentMillis - lastMillis > 6000UL && changeCount == 1)* * {* * Serial.println(“Dispenser: Leave”);* * changeCount = 0;* * handWash = 0;* * bed = 0;* * currentBed = 0;* * newBed = 0;* * lastMillis = currentMillis;* * clearTag(tagString);* * clearTag(storeString);* * }* * }* } void checkHandwash() { * currentMillis = millis();* * buttonState = digitalRead(buttonPin); //read the state of the button pin * if(buttonState == HIGH/vw_get_message(buf,&buflen)/) //when button is pressed * {* * clearTag(tagString); //clear previous Bed Tag* * readTag(); //read dispenser tag* * resetReader();* * if(compareTag(tagString,dispTag))* * {* * offAlarm(); //off alarm* * handWash = 1; //indicate hand is washed* * newBed = 0; //newBed = 0 as current bed is Bed A, so no new bed* * lastMillis = currentMillis; //store time when dispenser was last used* * clearTag(tagString); //clear dispenser tag* * if(strlen(storeString) != 0)* * {* * for(int i = 0; i < strlen(storeString) ; i++)* * {* tagString = storeString*; //copy stored string to tagString* * }* * }* * }* * }* } void checkLED() { * currentMillis = millis();* * while(digitalRead(ledPin) == HIGH) //after leaving bed, alarm ons* * {* * checkHandwash();* * if(currentMillis - lastMillis < 10000UL && handWash == 1) //if hand wash within 10 seconds after alarm is switched on* * {* * Serial.println(“Bed: Leave Compliance”);* * compliance++; //increase compliance count* * handWash = 0;* * lastMillis = currentMillis;* * offAlarm();* * clearTag(tagString);* * }* * else if(currentMillis - lastMillis > 10000UL && handWash == 0) //if alarm on for 10 seconds, record non-compliance* * {* * Serial.println(“Bed: Leave Noncompliance”);* * noncompliance++;* * lastMillis = currentMillis;* * offAlarm();* * } * * }* }
void checkLast() { * currentMillis = millis();* * if(currentMillis - lastMillis > 6000UL)//check for hand wash within the last 6 seconds* * {* * if(handWash == 1) //if hand wash is done more than 6 seconds ago, hand wash needs to be done again* * {* * Serial.println(“Reset Handwash”);* * handWash = 0;* * }* * lastMillis = currentMillis; //resets the time interval* * } * }
