counting problem
hello, everyone.
I face a probelm in programming my ardunio using IR sensor to do the following:
If IR sensor goes LOW, start counting until the it goes HIGH in which a varible called duration take the counting value, and then check for four states. While in each state there is a certain command.
The problem is I need counting goes to 0 after duration take its value, but it did not work becuase whenever I add count = 0; in the code the counting did not work.
Here is my code:
int LED1 = 4;
int LED2 = 5;
int LED3 = 6;
int LEDc = 7;
int IR = 2;
boolean currentstate; // Current state of IR input scan
unsigned long duration;
int count = 0;
  pinMode(IR,INPUT);
  pinMode(LED1,OUTPUT);
  pinMode(LED2,OUTPUT);
  pinMode(LED3,OUTPUT);
  pinMode(LEDc,OUTPUT);
  digitalWrite(LED1,HIGH);
  digitalWrite(LED2,HIGH);
  digitalWrite(LED3,HIGH);
  digitalWrite(LEDc,HIGH);
  delay(2000);
  digitalWrite(LED1,LOW);
  digitalWrite(LED2,LOW);
  digitalWrite(LED3,LOW);
  digitalWrite(LEDc,LOW);
  count=0;
  currentstate = digitalRead(IR);
  if( currentstate == LOW )
  count++;
  Serial.print("Time: ");
  Serial.println(count);    //prints time since program started
  delay(1000);   // wait a second so as not to send massive amounts of data
if (currentstate == HIGH){
    duration = count;
    if (duration <=4 && duration >0){
      digitalWrite(LED3,LOW);}
    else if (duration >4 && duration <=7){
    else if (duration >7){
      digitalWrite(LED1,LOW);}
     else if (duration ==0){
    Serial.print("duration: ");
    Serial.println(duration);    //prints time since program started
Barahim:
hello, everyone.
Here is my code:
int LED1 = 4;
int LED2 = 5;
int LED3 = 6;
int LEDc = 7;
int IR = 2;
int count = 0;
  pinMode(IR,INPUT);
  delay(2000);
  count=0;
  count++;
    duration = count;
Is that why you unconditionally set count to zero each time through the loop?
Paul
I need the check being continuously while there is a state of the counting equal to zero. In the same time, I need counting value returns to zero each time the loop starts.
Basically, the idea is simple, there three LEDs:
Green when the counting is less than 5 and more than 0
yellow when the counting is less than 8 and more than 4
red when the counting is more than 7
Then you REALLY need to add Serial.println() showing what is happening rather than just guessing.
Paul
You got this part wrong...
The comment should read "Prevent the Arduino from doing anything useful for a million microseconds."
Use millis() for timing, don't invent your own counter.
