outsider:
Try this sketch with a pushbutton between GND and pin 4, press the button x number of times, if you pause for 1.5 seconds, the onboard led will flash as many times as you pressed.uint32_t tStart, timeStart, tEnd = 1500;
const byte dbTime = 25, btn = 4, ledPin = 13;
bool btnState = false, bState = true, oldBstate = true,
timing = false;
byte cntr;
pinMode(btn, INPUT_PULLUP);
pinMode(ledPin, OUTPUT);
// debounce-----------------------------
if (digitalRead(btn) != btnState) // they are different!
btnState ^= 1; // make them equal
timeStart = millis(); // restart timer
if (millis() - timeStart > dbTime) // if not changed for dbTime,
bState = btnState; // btnState is valid, use it
// end debounce-------------------------
if(!timing && !bState && oldBstate)
tStart = millis();
timing = true;
if(timing && !bState && oldBstate)
cntr++;
tStart = millis();
oldBstate = bState;
if(millis() - tStart > tEnd)
timing = false;
while(cntr > 0)
digitalWrite(ledPin,HIGH);
digitalWrite(ledPin,LOW);
cntr --;
oldBstate = bState;
outsider:
timing = false;
byte cntr;
tStart = millis();
timing = true;
cntr++;
tStart = millis();
oldBstate = bState;
timing = false;
while(cntr > 0)
cntr --;
oldBstate = bState;
Hi, outsider!...i tried this sketch and works perfectly...i was wondering if this sketch works to count fast? and if so, how can i modify it?
Thank you my friend
