Counting revolution of stepper - big number
When I counting revolution of motor (counting impulse) using:
 count;
  if (stepPinState == HIGH && runStepper >= 1)
    count++;
I get from serial monitor very big number like: 0, 7290, 17181, 27059, 36927, 46809, interval=1s.. I think it must be something like 0, 200, 400, 600. What's wrong?
long count = 0;
 if (customKey == 'A')             // stepper - left direction
    runStepper = 1;
    digitalWrite(sleepPin, HIGH);
    digitalWrite(dirPin, HIGH);
  if (runStepper >= 1)
    unsigned long current1 = micros();
    if(current1 - previous1 > interval)
      previous1 = current1;
      if (stepPinState == LOW)
        stepPinState = HIGH;
        stepPinState = LOW;
      digitalWrite(stepPin, stepPinState);
  count;
    count++;
unsigned long current2 = millis();
  if(current2 - previous2 > 1000)
    Serial.println(count);
    previous2 = current2;
Where's the rest of your code?
int relay1Pin = 23;   // relay
int relay2Pin = 25;
int relay3Pin = 27;
int relay4Pin = 29;
int sleepPin = 47;   // stepper
const int stepPin = 49;
int dirPin = 51;
int stepPinState = LOW;
long previous1 = 0;
long previous2 = 0;
long interval = 1000;
static byte runStepper = 0;
static byte autoStepper = 0;
long count = 0;
#include <Keypad.h>
const byte ROWS = 4;   // four rows
const byte COLS = 4;   // four columns
// define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
    '1','2','3','A'  }
    '4','5','6','B'  }
    '7','8','9','C'  }
    '*','0','#','D'  }
byte rowPins[ROWS] = {
  22, 24, 26, 28};   // connect to the row pinouts of the keypad
byte colPins[COLS] = {
  30, 32, 34, 36};   // connect to the column pinouts of the keypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);   // initialize an instance of class NewKeypad
  pinMode(relay1Pin, OUTPUT);     // relay
  pinMode(relay2Pin, OUTPUT);
  pinMode(relay3Pin, OUTPUT);
  pinMode(relay4Pin, OUTPUT);
  pinMode(sleepPin, OUTPUT);     // stepper
  pinMode(stepPin, OUTPUT);
  pinMode(dirPin, OUTPUT);
  char customKey = customKeypad.getKey();
  if (customKey == '1')             // relay 1 on
    digitalWrite(relay1Pin,LOW);
  if (customKey == '4')             // relay 1 off
    digitalWrite(relay1Pin,HIGH);
  if (customKey == '2')             // relay 2 on
    digitalWrite(relay2Pin,LOW);
  if (customKey == '5')            // relay 2 off
    digitalWrite(relay2Pin,HIGH);
  if (customKey == '3')             // relay 3 on
    digitalWrite(relay3Pin,LOW);
  if (customKey == '6')            // relay 3 off
    digitalWrite(relay3Pin,HIGH);
  if (runStepper == 0)             // stepper - stand by off
    digitalWrite(sleepPin, LOW);
  if (customKey == 'A')             // stepper - right direction
    runStepper = 1;
    digitalWrite(dirPin, LOW);
  if (customKey == 'B')             // stepper - left direction
    runStepper = 2;
        stepPinState = LOW;
  count;
    count++;
  if (customKey == 'C')    //stepper off
    runStepper = 0;
    autoStepper = 0;
  int sensorValue = analogRead(A0);  // read the input on analog pin 0:
  int currentValue = sensorValue * (3.3 / 1024.0)*100;
    Serial.println(currentValue);  // print out the value you read:
  if (customKey == 'D')
    autoStepper=1;
  if (currentValue >= 244 &&  autoStepper==1)
    runStepper = 3;
  if (currentValue < 244 && autoStepper==1)
    runStepper = 0;
what is the count;
statement supposed to do. RIght now it does nothing.
RMLR: I get from serial monitor very big number like: 0, 7290, 17181, 27059, 36927, 46809, interval=1s.. I think it must be something like 0, 200, 400, 600. What's wrong?
You're not counting the pulses, you're incrementing count every iteration of the loop when your two conditions are true. It sounds like you should be looking for transitions, like when stepPinState transitions from LOW to HIGH.
Thank you Arrch and KeithRB. This is my code.
 if (stepPinState != lastStepPinState) // if the state has changed, increment the counter
    if (stepPinState == HIGH)
      countImpulse++;
  lastStepPinState = stepPinState;
