Counting the number of touches_MPR121
Hi Everyone,
I am new to programming and Arduino. I am using Adafruit MPR121 Capacitive Touch Sensor. What I want to do is to count the number of touches for each touchpad.
For example, when I touch the touchpad 0 once, then it says touched once. I touch it twice, and it says touched twice and so forth. When I touch the touchpad 6, it says touched once. However, the code I have for now is counting the number of touches for all, not counting for the individual touchpad.
Instead of writing for each pad separately, how to write a loop to make it easier?
Here is my code:
#include <Wire.h>
#include "Adafruit_MPR121.h"
#ifndef _BV
#define _BV(bit) (1 << (bit))
#endif
uint16_t lasttouched = 0;
uint16_t currtouched = 0;
Adafruit_MPR121 cap = Adafruit_MPR121();
uint8_t touchThreshold = 100;
uint8_t releaseThreshold = 40;
int TouchCounter = 0;   // counter for the number of touches
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 50;
  while (!Serial) { // needed to keep leonardo/micro from starting too fast!
    delay(10);
  Serial.println("Adafruit MPR121 Capacitive Touch sensor test");
  // Default address is 0x5A, if tied to 3.3V its 0x5B
  // If tied to SDA its 0x5C and if SCL then 0x5D
  if (!cap.begin(0x5A)) {
    Serial.println("MPR121 not found, check wiring?");
    while (1);
  Serial.println("MPR121 found!");
  currtouched = cap.touched();
  for (uint8_t i=0; i<12; i++) {
    if ((currtouched & _BV(i)) && !(lasttouched & _BV(i))) {
      lastDebounceTime = millis();
     if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer than the debounce
    // delay, so take it as the actual current state:
    if (!(currtouched & _BV(i)) && (lasttouched & _BV(i))) {
      TouchCounter++;
      if (TouchCounter == 1) {
        Serial.print(i); Serial.println(" Touched Once");
        delay(50);}
      if (TouchCounter ==2) {
        Serial.print(i); Serial.println(" Touched Twice");
        delay(50);}
       if (TouchCounter >2) {
        Serial.print(i); Serial.println(" Playing");
        delay(50);}
   // reset our state
   lasttouched = currtouched;
   return;
  // debugging info, what
  Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t\t 0x"); Serial.println(cap.touched(), HEX);
  Serial.print("Filt: ");
    Serial.print(cap.filteredData(i)); Serial.print("\t");
  Serial.print("Base: ");
    Serial.print(cap.baselineData(i)); Serial.print("\t");
  // put a delay so it isn't overwhelming
  delay(100);
I have attached the image of the current result. It is not counting individual touchpad separately.
Thank you very much.
you only have one TouchCounter variable which is incremented for all pads.
do you want TouchCounter to be an array, "int TouchCounter [12] = {};" and in your code increment the count for a specific pad "TouchCounter ++;"?
also, you can simplify your debouncing by simply added a 50 msec delay to loop()
gcjr:
[/quote]
Hi, yeah, this is exactly what I wanted. I tried adding the array and it worked! Thanks!
